jorm
Post by jorm »
The pa45/7.36 crackles even more than pa44/7.35 with thesycon 2.20.No problems with M2Tech Young (and Amanero).So the problem is driver related.
Jorgen
jorm wrote:The pa45/7.36 crackles even more than pa44/7.35 with thesycon 2.20.No problems with M2Tech Young (and Amanero).So the problem is driver related.
Jorgen
As has often been the case.
There have been quite number of releases that act differently on Thesycon drivers than on Amanero.
Clive
Post by Clive »
Jorgen
Indeed. This is why jplay has parameters to allow set up for specific drivers.
Clive wrote:
Jorgen
if only I had a thesycon device, once upon a time I didn't have a 24 bit device.
I deleted a load of timer related code, maybe the devices use that, shall add it back in as pa45 sounds a bit too free.
uploaded portaudio v47, any better ?
Clive
Post by Clive »
7.36+v45 both SSE and AVX2 on ivy bridge sound great with some music. Bass on jazz (double bass) has a fabulous woody colouration. Great too on modern dry recordings. On music with slightly bloated bass the effect isn't so great.
No crackles with the Young driver (Octave mkII).
Clive
Post by Clive »
sbgk wrote:uploaded portaudio v47, any better ?
I can't speak for those with crackles but v47 has lost much of the loose bass on my system. Much moire balanced.
47 had a hiccup, try 48
Clive
Post by Clive »
I'd say the bass is about right, could be a trace shy or right. Either way it's tight and there's no masking of the mid and treble now so clarity is good.
John Dot
Post by John Dot »
Still the same on me.
