sbgk wrote:
nige2000 wrote:
bass doesnt have enough speed/agility in sharper bass notes,
fast piano one note smears into the next
likely all the same issue
wasapi still sounds livelier, clearer and more involving in the more challenging tracks
to me it's the most incredible sound I've heard.
How do you know your recording has sharp bass notes and clear piano, maybe that was an artifact of wasapi.
Think JK posted an article about lack of noise leading to less dynamic smoother sound.
Anyway there is still a bit of code to remove, if I can work it out.
How do you know your smoother sound is not a lack of resolution and detail?
Smeared sound can never be the objective of a recording?
aleg, why are you so bitter? maybe why your wife won't give you sex i bet
cvrle59
Post by cvrle59 »
You may want to get a "digital-vinyl" (double DSD) version of an album to listen first, then compare red-book played by MQn to it, so that may help on judging of "rightness" of sound.
I was blown away last night listening this (not just me, my friend too, who used to think that LP12 is miles away from digital)...thanks Ken for heads-up!
http://www.highdeftapetransfers.com/pro ... p?pid=8207
Just my 2 cents...
Jeez this is turning into PFM
I'm certain there's still better aspects in wasapi atm
Definitely not artifacts it's plain as day here
Otherwise I wouldn't have mentioned it
No point getting frustrated with each other
We're hardly out of road for ks yet
Dunno if setting dsd as a target is a good idea either
Though it is very good
cvrle59
Post by cvrle59 »
I have no doubt any more about DSD, we like it or not, especially DDSD.
BTW, it would nice to have more control on what we put in writing here, some stuff is out of context.
5.14 only just happens to sound good on particular settings.
2.71 is the one.
my OS went through 1000 changes ending with 100 changes.
i went from CPU=1.6Ghz to 4Ghz to 4.8Ghz to 4Ghz.
changed my ram timing 10 times.
i went from win8 to 2012 to R2 to "win8.1 with update" to 2012
2.71 survives all the way.
in fact, i remember everyone did like 2.71 because of its musicality. even for those users on win7.
after tweaking, 2.71 only gonna get more more details.
i bet if and when win9 comes out, 2.71 will survive.
am not sure about 5.14
now that's a reference version.
shoom
Post by shoom »
Hi All
I have PA 38 and mqnplay v 7.35 sse loaded at the moment and it’s astoundingly good to my ears.
More meat on the bones in the lower mid and bass.
I have Xmos drivers and like Jling I’m having the first few seconds at the start of playback cut off. It’s no big deal as the rest sounds so very good but I’ve had this before with other players that I’ve tried.
In my experience it has something to do with:
1) The latency setting on the Xmos drivers (I’ll have a play with that later)(what settings do you have for that Jonathan?)I have my settings @ lowest latency ATM.
2) The buffer size.(can only be set for KS in the programme).
Is it possible to have a feature for adjusting the buffer size? I may be wrong so feel free to correct if necessary.
Just a thought.
Great work guys
Great work Gordon.
shoom wrote:Hi All
Just a thought.
Great work guys
Great work Gordon.
I like the lowest latency and buffer settings for the xmos chip
Usually sounds a bit thinner but also more detailed and delicate
DJ le Roi
Post by DJ le Roi »
shoom wrote:Is it possible to have a feature for adjusting the buffer size? I may be wrong so feel free to correct if necessary.
+1
Period size?
Think it affects the alignment thing
