uploaded
- 7.08 mqnplay1644 sse2/avx2,
- mqncontrol 3.62
- listwdmksdevices.exe
put listwdmksdevices.exe in the same directory as mqncontrol/play/portaudio_x64.dll
- mqnparam.txt
put mqnparam.txt in the same directory as mqncontrol/play/portaudio_x64.dll
run listwdmksdevices.exe (double click on it) and note the device number then edit mqnparam.txt and replace 4 with the required no. max no is 8.
use with portaudio_x64 v24
find it a more natural sound than wasapi - Peter St (xxhighend developer) described wdmks as having soul
If you have mmcss enabled it will use that (pro audio profile), I have it disabled so the portaudio thread priority is adjusted automatically to highest - means the other applications are less responsive, whereas mmcss would try and balance things out.
lukivision wrote:
lukivision wrote:Using portaudio_x64.dll v23 and mqnplay 7.05 in normal versions, playback breaks suddenly after two or three pieces .
Luki
It seems that the sudden interruption of playback is due to the time that I choose to shutoff the display of my thinkpad t61 if not in use. This time is ten minutes. Just to clear that point. The new versions seem to be at least not worse, compared to Wasapi. So - keep on tweaking, Gordon!
Greetings from Bochum
Luki
7.08 has optimised copy so should be much better.
sbgk wrote: .....
max no is 8.
Highest device number on my development machine is at the moment 115.
Max of 8 is a bit low.
uploaded portaudio v25 and mqnplay 7.09, found incorrect setting for portaudio and sq tweak for mqn, the copy code still makes a difference.
uploaded portaudio v25 source code as required by licence, main changes are just removing as much code as I could that wasn't associated with wavecyclic render.
Aleg wrote:
sbgk wrote: .....
max no is 8.
is that as reported using listwdmksdevices.exe ?
either way will need further work to allow for higher nos.
sbgk wrote:uploaded portaudio v25 and mqnplay 7.09, found incorrect setting for portaudio and sq tweak for mqn, the copy code still makes a difference.
think mqnplay 7.08 was probably ok, the portaudio setting seems to have improved the sq a bit, but 7.09 is there for comparison.
think 7.09 edged it for me.
uploaded 7.09 24/96 sse2/avx2 versions and mqncontrol.exe v3.63 which is required for 24/96
sbgk wrote:
Aleg wrote:
sbgk wrote: .....
max no is 8.
yes:
Output devices:
13 - Microsoft Sound Mapper - Output [MME]
14 - Digital Audio (S/PDIF) (High De [MME]
15 - ADAT (3+4) (RME Fireface UCX) [MME]
16 - Speakers (Juli@ Audio) [MME]
17 - Juli@ Ch34 (Juli@ Audio) [MME]
18 - ADAT (5+6) (RME Fireface UCX) [MME]
19 - Speakers (RME Fireface UCX) [MME]
20 - ADAT (7+8) (RME Fireface UCX) [MME]
21 - Hi-Fi Cable Input (VB-Audio Hi- [MME]
22 - Analog (7+8) (RME Fireface UCX) [MME]
23 - Analog (3+4) (RME Fireface UCX) [MME]
24 - Juli@ Ch12 (Juli@ Audio) [MME]
25 - Digital Audio (S/PDIF) (High De [MME]
26 - SPDIF/ADAT (1+2) (RME Fireface [MME]
27 - Analog (5+6) (RME Fireface UCX) [MME]
28 - SPDIF coax. (RME Fireface UCX) [MME]
42 - Primary Sound Driver [Windows DirectSound]
43 - Digital Audio (S/PDIF) (High Definition Audio Device) [Windows DirectSound]
44 - ADAT (3+4) (RME Fireface UCX) [Windows DirectSound]
45 - Speakers (Juli@ Audio) [Windows DirectSound]
46 - Juli@ Ch34 (Juli@ Audio) [Windows DirectSound]
47 - ADAT (5+6) (RME Fireface UCX) [Windows DirectSound]
48 - Speakers (RME Fireface UCX) [Windows DirectSound]
49 - ADAT (7+8) (RME Fireface UCX) [Windows DirectSound]
50 - Hi-Fi Cable Input (VB-Audio Hi-Fi Cable) [Windows DirectSound]
51 - Analog (7+8) (RME Fireface UCX) [Windows DirectSound]
52 - Analog (3+4) (RME Fireface UCX) [Windows DirectSound]
53 - Juli@ Ch12 (Juli@ Audio) [Windows DirectSound]
54 - Digital Audio (S/PDIF) (High Definition Audio Device) [Windows DirectSound]
55 - SPDIF/ADAT (1+2) (RME Fireface UCX) [Windows DirectSound]
56 - Analog (5+6) (RME Fireface UCX) [Windows DirectSound]
57 - SPDIF coax. (RME Fireface UCX) [Windows DirectSound]
58 - ASIO 2.0 - ESI Juli@ [ASIO]
59 - ASIO Fireface USB [ASIO]
60 - Digital Audio (S/PDIF) (High Definition Audio Device) [Windows WASAPI]
61 - ADAT (3+4) (RME Fireface UCX) [Windows WASAPI]
62 - Speakers (Juli@ Audio) [Windows WASAPI]
63 - Juli@ Ch34 (Juli@ Audio) [Windows WASAPI]
64 - ADAT (5+6) (RME Fireface UCX) [Windows WASAPI]
65 - Speakers (RME Fireface UCX) [Windows WASAPI]
66 - ADAT (7+8) (RME Fireface UCX) [Windows WASAPI]
67 - Hi-Fi Cable Input (VB-Audio Hi-Fi Cable) [Windows WASAPI]
68 - Analog (7+8) (RME Fireface UCX) [Windows WASAPI]
69 - Analog (3+4) (RME Fireface UCX) [Windows WASAPI]
70 - Juli@ Ch12 (Juli@ Audio) [Windows WASAPI]
71 - Digital Audio (S/PDIF) (High Definition Audio Device) [Windows WASAPI]
72 - SPDIF/ADAT (1+2) (RME Fireface UCX) [Windows WASAPI]
73 - Analog (5+6) (RME Fireface UCX) [Windows WASAPI]
74 - SPDIF coax. (RME Fireface UCX) [Windows WASAPI]
87 - Analog (5+6) (Fireface Analog (5+6)) [Windows WDM-KS]
89 - ADAT (7+8) (Fireface ADAT (7+8)) [Windows WDM-KS]
91 - Analog (7+8) (Fireface Analog (7+8)) [Windows WDM-KS]
93 - SPDIF coax. (Fireface SPDIF coax.) [Windows WDM-KS]
95 - SPDIF/ADAT (1+2) (Fireface SPDIF/ADAT (1+2)) [Windows WDM-KS]
97 - Analog (1+2) (Fireface Analog (1+2)) [Windows WDM-KS]
99 - ADAT (3+4) (Fireface ADAT (3+4)) [Windows WDM-KS]
101 - Analog (3+4) (Fireface Analog (3+4)) [Windows WDM-KS]
103 - ADAT (5+6) (Fireface ADAT (5+6)) [Windows WDM-KS]
105 - SPDIF Out (HD Audio SPDIF out) [Windows WDM-KS]
106 - SPDIF Out (HD Audio SPDIF out 2) [Windows WDM-KS]
107 - Line Out (Juli@ Ch12) [Windows WDM-KS]
109 - Output (Juli@ Ch34) [Windows WDM-KS]
111 - SPDIF Out (Juli@ Ch34) [Windows WDM-KS]
112 - Speakers (Juli@ Multi-4 ch) [Windows WDM-KS]
115 - Speakers (VB-Audio Hi-Fi Cable) [Windows WDM-KS]
Hopefully will put aside some time to work this out tonight. Wonder is it worth getting the mods to move it to a new thread? MQN KS perhaps?
either way will need further work to allow for higher nos.[/quote]
yes:
Output devices:
I only get wdmks devices, are you using the latest portaudio, which device are you wanting to use ?
