Found this on Touch the other day.After a very quick listen to the Iannis Xenakis stuff, maybe this might appeal to you?
Have a listen to the sample.The text makes an intriguing read anyway... and it's only £2.00 for a slightly damaged vinyl artifact (sleeve).
http://touchshop.org/product_info.php?c ... ucts_id=71
mcq
Post by mcq »
Interesting, but I wonder whether we would approach the music in the same way if it was marketed as an actual piece of music as opposed to something that is simply designed to induce a hypnogogic state. Seems a bit contrived to me, but I'm sure something similar is used in subliminal TV advertising to invoke a suitably receptive state in the viewer.
mcq wrote:Interesting, but I wonder whether we would approach the music in the same way if it was marketed as an actual piece of music as opposed to something that is simply designed to induce a hypnogogic state. Seems a bit contrived to me, but I'm sure something similar is used in subliminal TV advertising to invoke a suitably receptive state in the viewer.
My sentiments exactly;didn't stop me getting the (last) copy though?!?!
cybot wrote:Jad, I would urge you to get this amazing album. Mine is a vinyl copy with a whole 20 minutes
tagged on on Side 4 :-)) Read the review and see what you think...Sad to see it's sold out :-((
http://boomkat.com/cds/225409-thomas-k-ner-la-barca
Cybot,
This sold for $51 on e-bay.Hopefully this will come up for sale again.
Cybot,
Wow!!! - amazing what a limited item can fetch!! It's still available on the Experimedia site for around $25.00 for a vinyl copy... So you'll just have to get yourself a TT :-))...
Just ordered these from the Kats :-))
7" taster from their (imminent) new album...
Have waited and waited and waited for a vinyl release of this magnificent anthology. It's a triple vinyl
set and it is available now.Will sit very nicely beside Vol. 1 :-))) Can't wait...
http://boomkat.com/vinyl/305640-various ... c-volume-2
Adrian
Post by Adrian »
Currently listening to Nick Warren, Global Underground GU 35 Lima,
I must admit I do like the GU series. Not all are to my taste, but there are some good ones.
Pantha Du Prince:Black Noise.Great techno.
jadarin wrote:Image
Hi Jad, I've looked at it loads of time but ended up buying something else instead.Will have to check it out...I think Dave from Road likes it too.
jadarin wrote:Image
Cybot,
This is minimal techno full of surprises and always easy on the head.
