lekt player
Re: lekt player
lekt wrote:
jesuscheung wrote:
lekt wrote:uploaded lekt.exe1644v1.9 with specially method for render loop.
try it and enjoy!
1.9. no sound. no exception. just stuck.
1.1. no sound. no exception. just stuck.
wait for some time, it's mean buffer management of your sound card and of mine differences. this version have very good bass depth, i will fix it.
lekt. i finally have figured out the best buffer for my DAC. it has to be 1ms, 2ms, 4ms, 8ms, or 10ms. i have tested it in foobar and XA and mediamonkey. my native ASIO only supports those buffers too.
anyway, i am currently using 8ms or 352 for XA. it is by far the best buffer for my STX DAC. i mean it, it is perfection.
not sure why lekt player doesn't work with 352. only 256/512/1024 works.
you have to make 88, 176, 352 etc work for me! can't wait to test.
lekt
Re: lekt player
Post by lekt »
lekt wrote:wait for some time, it's mean buffer management of your sound card and of mine differences. this version have very good bass depth, i will fix it.
uploaded lekt.exe v2.7 1024
try it.
Re: lekt player
try it.
sorry. no sound. no exception. stuck.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:sorry. no sound. no exception. stuck.
uploaded lekt.exe v2.7.1 1024 , not sure it works with your soundcard or not. OK with my laptop onboard card.
maybe your card have security so that don't let hack to buffer. i removed "..GetBuffer(...);" (as yesterday i said), sound so much better in my case, latency much reduced. try this version, code changed proccess in render loop. hope...
lekt
Re: lekt player
Post by lekt »
uploaded lekt.exe v2.8 1024
Re: lekt player
hmm... no working... 2.7.1... 2.8....
same. no sound. no exception. stuck.
i have pagefile enabled.
why would my soundcard has security!!! what is there to hack!!
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:why would my soundcard has security!!! what is there to hack!!
ah my english so bad. not hack, some readings variable pointer when not right, i catch it in my case, very benefit for reducing latency. v2.8 good, is best of all lekts. maybe you test in other laptop. my card works OK. unfortunatelly. im try more.
Re: lekt player
on my laptop win7:
2.7.1 plays distorted music.
2.8 plays crackling noises. threw an exception: "The instruction at 0x3f67124c reference memory at 0x00462000. The memory could not be written"
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:on my laptop win7:
incompatible with your sound card. restored "GetBuffer(..)" in code to normal process mode.
uploaded v2.9 1024 with many things optimized. i happy with this sound, open/free, mellow.
Re: lekt player
2.9 1024 (tested in R1)
-better! very good. mellow. airy.
-hard trebles are mellowed into vibrations. excellent.
-main/loud part of music is full and deep and revealing.
-but quieter part of music lacks full and deep and revealing.
-i hear layers!
-vocal needs more vocal vibration. need to shake the room!
-drums are super. think it's best drum sound on earth.
-even on cheaper headphones, the bass/drums feels like the real thing!
-eminem Stan used to have this horrible drums in the background. it sounds real now!
