I take it everyone has listened 2.60 sse4 intel 8 4
Haven't had any bad feedback so shall use that one for 24 bit etc
sbgk wrote:I take it everyone has listened 2.60 sse4 intel 8 4
Ok with me
fav of the2.6's
could live with most of the last few
much work involved in the 24 bit
Assuming you need to build from an existing version
Will it alter the sound?
LowOrbit
Post by LowOrbit »
That version is very good, so an ideal platform for 24 bit development.
listened to it again, very good micro detail, just a tad bass shy
couldnt say that
this far in we may begin to realise the differences with pc equipment
there seems to be many many things that affect the sound
what you going to do go for another version/variant
couldnt say that
I have some options.
what pc setting would you use to add bass ?
I guess I'm comparing it with the normal balance I get with other players.
For me the pc settings don't make that big a difference, to the extent where they are nice to have, but can live without them.
Edit you posted this yourself Sbgk about 2.60 a bit bass shy but if you get 24bit version working on that I can see you doing the same subsequently that has occurred with 2.59. i.e. you will cover all bases with your experiments and fill out any gaps that people perceive.
prefer not to, that's why I trying to get a settled version.
I need to go off and have a listen to the 2.60 versions as I have been enjoying a variety of the 2.59's over the last couple of days albeit with vey minimal listening time. As I seem to post a lot these days it will be early next week before I can have a decent go at it. Probably too late to influence choice but happy to go with the flow.
Just another question is that version similar to the longwinded 2.59 regarded as bass shy? I didn't find that one too shy if that helps.
tony wrote:I need to go off and have a listen to the 2.60 versions as I have been enjoying a variety of the 2.59's over the last couple of days albeit with vey minimal listening time. As I seem to post a lot these days it will be early next week before I can have a decent go at it. Probably too late to influence choice but happy to go with the flow.
has more bass than that 2.59 one.
