cvrle59
Post by cvrle59 »
nige2000 wrote:
jesuscheung wrote:i think 4.87 has treble issue
Steinway & Sons sounds like a Yamaha...
Motorbike or keyboard?
2-stroke/3-cyl Outboard...:)))
4.96 sse is good. rich.
4.74 sse is better. little thinner.
both versions have tight bass. but 4.96 is tight also tense.
(4.74 is only slightly tense. ok)
jesuscheung wrote:4.96 sse is good. rich.
Try 4.95, my initial impression is that it is somewhat more relaxed, but still has the same level of bass control of the 4.96.
I find 4.95 more emotionally engaging than 4.96.
Yes, I like the 4.95 better on several accounts.
think jc is sse2 bound
haswell only working avx now i think
is it worth upgrading your pc for avx?
yet again rhetorical ;)
uploaded 4.98 avx/sse2, shows promise, tried a different compiler for the render loop and seems to make a difference
almost sounds like music
the compiler does a 2 pass compile, so presumably is doing some optimising and the code is also in a different place in the exe, surprised it makes a difference, but I can hear the vocals better now and as I said it sounds like music.
probably more things to discover as there are more options to try/understand with this compiler.
this is a tweaked version of 4.95, probably a bit live and loose for Aleg, but it can be taken back to give more control, I just like the live sound, couldn't really care about the bass control.
have thought about a z87, z97 board.
(asus z87m-plus seems best. only board with dedicated irq for pcie slot as it seems)
but...
took me months to coming up with a "correct" bios... i have no energy to do it again...
does AVX2 make tighter bass, improve micro-level/quality?
i am sickened by the quantity generated from tweaking. quality not enough.
more bass, more detail won't impress me anymore... need quality
sbgk wrote:uploaded 4.98 avx/sse2, shows promise, tried a different compiler for the render loop and seems to make a difference
yes yes... 4.98 sse is good. (AVX WON'T PLAY)
seems to play pink floyd with ease. has a good stage
delay is good.
flow is good.
this new compile gives different sound texture/vibration.
quite like it. calm. ok engaging. mellow. feels sleepy?!
need more sharpness for guitar. need more weight for rock/drum.
slightly tense. has no other earache issues.
sbgk wrote:...
Loss of bass control is for me sign of bad player design.
Control of bass is again one of those aspects that high-end hifi gear aim for.
For me it is a sign of quality.
Aleg wrote:
sbgk wrote:...
seems true. most real sound i heard also has tightest bass
...as though hifi equipments have disappeared
softer bass can also make live and real. just that... you know it has coming from a pair of speakers
Aleg wrote:
sbgk wrote:...
+1
