Like
Yes
22
100%
No
0
No votes
Total votes: 22
the T bar is a method of keeping the signal currents away from the power currents
wonder can we cut from a sheet of copper, maybe james healys?
these are the ball bearings were hoping to use for the knobs to provide that extra smoothness
the rest of the power on switches
abraxalito
Post by abraxalito »
nige2000 wrote: Wed Jun 07, 2017 9:28 pm the T bar is a method of keeping the signal currents away from the power currents
To get the best separation (actually its the voltage drops caused by the currents we need to be concerned about) then the contact point between them should be as narrow as possible. In the set-up shown you'll have a slight voltage difference across (left-right) the downward stroke of the T caused by those power currents. So connections made to the right side will be at a slightly different potential to those made to the left.
abraxalito wrote: Thu Jun 08, 2017 1:37 am
im sort of screwed with this distance, im stuck with it we had to split the battery packs apart. Well just have to make the best of it
just shouldnt be very sensitive though should it, impedance should be relatively low?
ive seen guys put power resistors between power gnd and signal gnd,
dont think thats any sort of a solution though as i found that that sort of deadens or smoothes the sound as well as lowering noise
ive seen more sensitive dramatic grounding effects with a class a mosfet amp with same/similar power supply
these spacers really made this sturdy
Yeah, it looks great, really sturdy looking
I wonder if we mightnt be better off using a bar from pole to pole but then using some 2.5 or 4 sq wire from there out to the signal ground point.
Whats the story are we still chopping aluminium with a chainsaw tomorrow?
nige2000 wrote: Tue Jun 06, 2017 11:17 am Yes maybe here on Sat for a casual type of thing
We could cut some aluminium
Get this prototype functional
Is there anything to be done tomorrow Nige?
I am available if needed.
up to you guys,
i could do between 1 and 5pm if it suits if not, another time is fine
OK maybe better to pass for this weekend given that a few are heading to Gerry's tomorrow for the Vinyl get together.
