lekt player
Re: lekt player
modded flash player! sounds very well! better youtube SQ in firefox and chrome.
for chrome, go the about:plugins -> choose the mod. don't use that flash which built-into chrome.
try it
https://drive.google.com/#folders/0B9ZK ... 2ZwUkp2S28
read instructions in readme.
try it
Re: lekt player
i retested 2.38.2 and 2.36.3, careful. soundstage normal in my laptop, ~exactly XA1000 ASIO (maybe a bit of bit... lesser width, think normal), only foobar2000 running in realtime priority, here's sound have difference in intense. i see when running in this mode (or high priority also) seems better, more transparent, more intense, more clean. but lesser open/free sound, tired when long time listening, JC. do careful test in these modes. CD player sound very open/free.jesuscheung wrote:no. maybe 2-3% less than XA. assume XA is correct. also assume my OS tweak is correct.
then i don't set lekt player priority in code, let's user do this by .bat file if he likes this.
your 2.38.2 mod file: vibration OK, but soundstage changed, lesser width (or something likely width/height changed, very difficult detect coz this mod version have non-stability sound), sound has become nearer at listener. maybe you changed mod method, or you set windows with clock resolution specially for XA.
lekt player can give good sound in default windows environment, in my case default setting Pro Audio clockrate 10000 is best, very open/free sound. will try more improve vibration, musical emotion, more take care about soundstage.
Re: lekt player
yes... clockrate is wrong (i have 8ms)! set clockrate=10000. soundstage better.lekt wrote:i retested 2.38.2 and 2.36.3, careful. soundstage normal in my laptop, ~exactly XA1000 ASIOjesuscheung wrote:no. maybe 2-3% less than XA. assume XA is correct. also assume my OS tweak is correct.
i need to be more careful. recently version 2.37x to 2.38x becomes very sensitive. like ramdisk is bad, wrong clockrate is bad, mod is bad!
older versions doesn't matter.
alright. now, sound is a little earaches+dry. overall is gooood
Re: lekt player
hopefully, i am listening to what you are listening now!
2.36.3 & 2.38.2
-soundstage. try expand it a bit. width and height.
-earaches! my previous clockrate kills all earaches!
relistening!
2.31. has better sound at the "top left" of headphone.
2.36.3 & 2.38.2
relistening!
Re: lekt player
i am testing too:lekt wrote: i retested 2.38.2 and 2.36.3, careful. soundstage normal in my laptop, ~exactly XA1000 ASIO....
your 2.38.2 mod file: vibration OK, but soundstage changed, lesser width...
2.38.2+clockrate 10000 = good stage
2.38.2 mod + clockrate 10000 = bad stage
2.38.2 mod + clockrate 8ms = good stage
2.38.2 + clockrate 8ms = bad stage
so, my result is similar to you.
(in my setup i have 8ms because my dac likes 8ms, works for flash, foobar, xa, mqn, hqplayer and lekt player depends on version hehe...)
Re: lekt player
don't give up, your mod method very interesting, may use with .exe, .dll, after compiling, can make for individual purpose depend on hobby. i'll try later (tried, but bad result, .exe crashed! hehe...).jesuscheung wrote:...recently version 2.37x to 2.38x becomes very sensitive. like ramdisk is bad, wrong clockrate is bad, mod is bad!
only adjust good vibration versions more difficult, as in my case optimization code. better vibration always makes sound nearer at us and reduces sound width, damn!
Re: lekt player
if i have time in weekend, will spend a day playing with stack and heap.
have you tried my flash mod? it is best player in the world. hehehe... when i watch youtube live music performance, it is better than mqn, lekt, xa because the soundstage is totally correct. and emotion is full. of course, it is less vibration, less resolution!
i need to figure out how to play wav files with Adobe flash player.
Re: lekt player
thx, now very bussy with code, will do later.jesuscheung wrote:if i have time in weekend, will spend a day playing with stack and heap.
there's onething interesting, .aac audio codec usually more soundstage, more stereo effect than original .wav source. DSP can make all things. currently youtube video uses aac (older used mp2, mp3), seems better sound, but it's DSP effect, i like mp3 more than, coz keep original soundstage. but mp3 more blur than aac (compare 2 file with same size). better only with wav, hehe...
Re: lekt player
oh, ic!!! that's pretty damn good DSP by google/youtube.
but flash sounded wrong before i modded it. digital + incorrect soundstage.
i only changed majorlinkversion from 09 to 0A. 1 letter changes everything! pkshan is genius!
Re: lekt player
uploaded v2.39 256 , all things a bit better, sound width expanded and in norm. vibration seems more correct and sound have become stability, mellow, emotion. try it.
