Ken Moreland wrote:Nige,
If you find something affecting latency you could update the driver or you could uninstall or disable if the application is unnecessary. I did this with Nvidia Display driver, got a latency improvement and was able to reduce UltraSize from 160 to 120.
I'd be very careful about uninstalling though unless I was sure what I was doing.
Yes I've been listening to V5.1 and it is very impressive. I'm using UltraStream all the time now and the atmosphere it creates is superb. If I walked into a room where Xtream was playing the sound would be excellent, detailed,musical etc but switch to UltraStream and it's goosebump territory. I'd like to explore the lower reaches of UltraSize and I'm envious on those who can go down to 20 but I'll wait until the network card controversy is resolved and the brighter sparks on this forum get the home built PC sorted.
Do take a chance to call round anytime suits you.
my i3 build gets down to 28us on ultrastream its been playing faultless with jplay 5.1 but gets an odd click or pop on 26us,
ill bring it with me when i call down, hopefully we will get 28us on the ciunas and see what its like.
nige
Well, I just pulled the trigger on the i7 3770 processor - best I could find was 264.89 on german ebay for new but tray packed so without the cooler etc. Seems the best deal I could find.
So add this to the costs from before and the total build is coming in around 484 or so:
Costs so far:
intel board: 96
picoPSU: 55
ram: 50
heatsink: 18
chip: 265
I already have the case, SSD, power supply for the pico, W8. So for some others that would need to be factored in. Cost excludes little bits and pieces like the umbilical cord from the linear power block to the PC etc.
nige2000 wrote: whats causing the spike ?
and the page file errors, i didn't find a solution as yet
how did you get on with yours john?
On my netbook, I found the culprit that causes the spike was Windows Defender - anti-virus software - I disabled it through Apps & now have 0 Pagefaults.
I was getting a spike like you & this was stopping Jplay Ultrastream in single PC mode (even at 200 Ultrasize setting) - it was annoying - about to test it now with Jplay.
Josef did say that antivirus and err, something else were the usual main culprits.
the i3 is playing hi res nonstop perfect in single mode at 30us in ultrastream i suppose that the main thing
im turning off windows defender atm, ill recheck latency now
fingers crossed
wouldn't mind i read the post on jplay about antivirus before (stupid me)
windows update was the other thing....
Highest measured interrupt to process latency (µs): 98.659620
Average measured interrupt to process latency (µs): 1.966838
Highest measured interrupt to DPC latency (µs): 96.673184
Average measured interrupt to DPC latency (µs): 0.679327
cd wav rip = 24us
hi res 24/ 192 = 28us
LatencyMon has been analyzing your system for 0:05:21 (h:mm:ss) on all processors.
_________________________________________________________________________________________________________
SYSTEM INFORMATION
Computer name: JPLAYENT
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: H67N-USB3-B3, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i3-2105 CPU @ 3.10GHz
Logical processors: 4
Processor groups: 1
RAM: 6061 MB total
CPU SPEED
Reported CPU speed: 3093.0 MHz
Measured CPU speed: 2049.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
MEASURED SMI, IPI AND CPU STALLS
The SMI, IPI and CPU stalls value represents the highest measured interval that a CPU did not respond while having its maskable interrupts disabled.
Highest measured SMI or CPU stall (µs) 0.662145
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 6.106693
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.000454
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.000712
ISR count (execution time <250 µs): 15317
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 153.165212
Driver with highest DPC routine execution time: ndis.sys - NDIS 6.30 driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.032084
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.069247
DPC count (execution time <250 µs): 1179162
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 0
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 11
Hard pagefault count of hardest hit process: 4
Highest hard pagefault resolution time (µs): 1619.931781
Total time spent in hard pagefaults (%): 0.000370
Number of processes hit: 2
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.099531
CPU 0 ISR highest execution time (µs): 6.106693
CPU 0 ISR total execution time (s): 0.009145
CPU 0 ISR count: 15317
CPU 0 DPC highest execution time (µs): 153.165212
CPU 0 DPC total execution time (s): 0.884354
CPU 0 DPC count: 1177221
CPU 1 Interrupt cycle time (s): 0.501151
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 20.898804
CPU 1 DPC total execution time (s): 0.001613
CPU 1 DPC count: 636
CPU 2 Interrupt cycle time (s): 0.530086
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 10.186874
CPU 2 DPC total execution time (s): 0.001851
CPU 2 DPC count: 644
CPU 3 Interrupt cycle time (s): 0.721228
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 34.701584
CPU 3 DPC total execution time (s): 0.001881
CPU 3 DPC count: 661
Those are sweet looking numbers, Nige. You need to revisit the links.
Got another pagefault spike & tracked it down to Windows Search Indexer - turned this off too.
Seems I have low page faults now.
Decided to go with this WTG config to boot my NUC.
Into the usual network issues of not connecting - can't pink between the netbook & NUC using ethernet cable.
Disable WiFi card on both NUC & netbook.
Set NUC ethernet IPV4 IP to fixed addr 192.168.1.30, subnet mask 255.255.255.0.; default gateway 192.168.1.1
Set Netbook IPV4 IP to fixed addr 192.168.1.31, subnet mask 255.255.255.0.; default gateway 192.168.1.1
I'm slightly hampered by not having a screen or keyboard attached to NUC so working blind but I have booted it with WTG before, attached to HDMI TV & it boots fine into Win8
no keyboard or monitor, that must be a big pain
can u not use a tv and steal a keyboard from somewhere, it will slow u down a lot id imagine
i think when your Ethernet adapters are different on the nuc and laptop you lose your settings when you swap the WTG over as there will be network adapter 1, 2, 3 depending how many pcs you've plugged the WTG into
