It doesn't work for most of us, can give a lot of distortion or won't play at all.Claus wrote:Sorry I have been out of the loop for a while. Can someone direct me to the files I need to get 3.39avx working?
Thanks!
Don't need special files to get it working when it does.
Hi claus
3.39 is only working for me dunno why
This 3.14 ain't bad
https://www.dropbox.com/sh/h6hg0cia6ndx ... NTY5qE4uaa
This 3.14 ain't bad
relistening to 3.39 sse. great version. drum weight is 100%. high energy. treble has good bass. my favorite kind of treble tune.nige2000 wrote:Hi claus
This 3.14 ain't bad
micro is little messy -> earaches.
can cause ear damage with headphones hehe. speakers is fine.
The 3.39 avx2 jcjesuscheung wrote:relistening to 3.39 sse. great version. drum weight is 100%. high energy. treble has good bass. my favorite kind of treble tune.nige2000 wrote:Hi claus
This 3.14 ain't bad
Micro is really good
Shame it's not working for most of you guy's
isn't there a AVX2 version for 3.40?
i find micro in 3.40 is better than 3.39
but 3.39 has the bass
i suspect you have RSAT running in your R2.nige2000 wrote:......
The 3.39 avx2 jc
when RSAT is enabled(not neccessarily running), it can negate the micro-messiness into glory.
can you check
dism /online /get-features
look for RSAT, and see if it is enabled? thx
rst-rds-tools-featuresjesuscheung wrote:i suspect you have RSAT running in your R2.nige2000 wrote:......
The 3.39 avx2 jc
can you check
disabled
couple of other rsat in name also disabled
most are disabled
will dig up 3.4 later
