JLP wdm-ks player
homeend
Re: JLP wdm-ks player
Post by homeend »
Hi.
I try to use JLP modified portaudio & squeezelite with my Audinst DAC mx1, and I got only this from debug file:
[22:21:27.123] test_open:183 no available rate found
[22:21:27.123] output_init_common:365 unable to open output device
Is it possible to use my DAC with JLP mod? Could changing some help or this require fixing in code ?
Michal
homeend wrote:Hi.
Michal
does it work with wdm ks output from original squeezelite and pa ? Maybe the dac doesn't have wdm ks driver.
what bit depth/sample rate is the file and does the dac normally play it ?
