----TWEAK 71----
realtek lan
disabled vs enabled
i am not happy at all!
1. realtek driver vs MS driver
more res + more jitter
less res + less jitter
hmm... either way sucks...
disabled vs
1. enabled + default settings
jitter level +3% (measured by digital strain, bloated, dirty etc)
quantity is kept
2. enabled + interrupt moderation set as false
jitter level +0.5%
quantity (mostly density, texture) -2 to -3%
hmm...
apart from "interrupt moderation", every other setting must be default or SQ will drop.
3. disable it in bios
happy happy
internethandle
Post by internethandle »
Yeah I have also resorted to disabling Realtek LAN in BIOS, easily best SQ, IMO. If I want to browse internet while doing critical listening, I just use a laptop.
Redistributable libraries for Intel C++
update3 is out
https://software.intel.com/sites/defaul ... .3.202.zip
worth trying
install and effective immediately. if don't like the sound, uninstall it.
i sometimes like it. sometimes don't. i do miss it from time to time.
actually, i am starting to see the benefit of disabling "interrupt moderation" in realtek lan. because jitter is less i can accommodate tweaks that weren't possible before. realtime priority is 5x more effective that it was. lost of resolution is restorable.
with "interrupt moderation" enabled, it injects dirty sound that is difficult to resolve.
internet latency improves too! browsing has better response
----TWEAK 72----
bcdedit
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
this little thing seems irrelevant but affects sounds a lot.
had been testing this for a long time. my description should be quite accurate.
for win7 and above
bcdedit /set usefirmwarepcisettings Yes
bcdedit /set nx AlwaysOff
explanation
-tightened timing. improve focus.
-if OS is strain, this will make more strain
-if OS lacks micro, you will experience air feeling with lack of texture.
-if you OS is like mind, without these, i shall have too much details -> bloated sounds -> quantity > quality
for win8 and above
bcdedit /set disabledynamictick on
explanation
-tighten timing. improve focus
bcdedit /set bootmenupolicy standard
explanation
-in win2012/R2, boot mode is different to win8.
-this boot mode improves focus. make sound more together.
---EXPERIMENT CANCELLED
bcdedit /set tscsyncpolicy Enhanced
explanation
-VERY INTERESTING. usually a tweak is either better or worse. correct or incorrect.
-this one is different.
-am using it. quite like it. more musical at the expense a few things. weight, balance are different. you have to listen to decide.
---EXPERIMENT
bcdedit /set disableelamdrivers yes
explanation
-redistribute sound frequency. more together.tidy. better focus. seems some detail is lost? actually the sound is should be more solid + richer.
-if your OS is spotlighted, this tweak will make it more spotlight.
-if your OS has 3D effect, this tweak will make more 3D.
TO CANCEL THE TWEAK:
bcdedit /deletevalue disableelamdrivers
bcdedit /deletevalue disabledynamictick
bcdedit /deletevalue bootmenupolicy
bcdedit /deletevalue usefirmwarepcisettings
bcdedit /deletevalue nx
bcdedit /deletevalue tscsyncpolicy
win8/8.1 users:
don't
your boot mode is default to standard
updated above tweak 72
CANCELLED
excessive energy.
retested my ram bios setting:
my ram is rated at 1600Mhz 9-9-9-24-2
2000Mhz 11-11-11-30-2 still sounds great.
was at 1.54v.
changes to 1.545v.
0.005v is not small difference.
at 1.54v, a little dryer, however quantity in excess.
at 1.545v, mellow. watery. quality>quantity.
>=1.55v, not good.
never cease to amaze me how same tweak has different effect over time....
when first starting tweaking, ram timing at:
12-12-12 was best. my first impression was easily the most analog sound.
after OS was a little more optimized. details more. sound started to congest. blurry. stress kicked in.
11-11-11 became best.
10-10-10 was silky smooth.
today, am surprised at the quantity/details it can produce. is it higher quality than 11-11-11??
10-10-10 needs 1.56v to sound best.
shall see
EDIT
my CPU setting is perfect. never once did i want to change it. thx to pkshan. just copied his settings. same frequency same voltage same CPU
only when i occasionally feels crazy wanting excessive quantity of bass for rock music, i start to oc CPU to 4.8Ghz.
EDIT2
no change in opinion. best timngs remain at:
2000Mhz (refined)
11-11-11-19 and 11-11-11-30, direct vs full resolution
800Mhz (raw)
6-6-6-11 and 6-6-6-17 for 800Mhz, direct vs full resolution
software update:
1. intel sata driver is out:
13.1.1052 > 13.0.2.1000
briefly tried 13.0.3.1000. thought it sounded crap.
2. mpc xa6.20 avx is out:
SQ seems better. music presentation sounds like xa. main music is 100%. background music is quiet maybe slightly normalized. is this good for movies?
i use it because graphic renders a lot faster than vlc using my crappy graphic card. vlc handles certain wmv files better.
in win2012/R2, you need to enable the server-media-foundation from server manager to activate the "Enhanced Video Renderer" in mpc.
alright...
learnt a new testing method.
a lot of what i posted is wrong.
from CPU voltage to many little things
basically 1 in 10 things i said is wrong. lol
shall do a massive update. soon....
