USB isolator tour
Re: USB isolator tour
jkeny wrote: Tue Jun 06, 2017 6:36 pm Sorry I couldn't leave that ISO-HUB with you but it is winging its way to the USA today.
That's ok, I have these big 12" CDs to keep me going in the meantime!
First brief listening report on ISO-DAC
"The sounds coming out of my speakers now makes me want to cry. While I expected to hear a bit of a difference between my dragonfly red and your setup, I was not prepared for what I'm hearing now. It's just brilliant! Nice job."
Finally got the Uptone Iso Regen this week and hooked it up using the battery pack that comes with the Ciunas Iso Hub and it works a treat with the battery supply.
Initial impressions are very good and the comparison will be tougher to sort a winner than I might have thought.
Will try to get some time over the coming week for some back to back listening but this weather is not helping!
Sligolad wrote: Wed Jun 21, 2017 1:18 pm Finally got the Uptone Iso Regen this week and hooked it up using the battery pack that comes with the Ciunas Iso Hub and it works a treat with the battery supply.
Did you order the Iso Regen without power supply?
I wonder how it compares with it's stock PS i.e what difference the battery PS makes
Don't you have one of their Meanwell PS that came with the original Regen?
6.6V battery power from ISO-PS works fine for the iso Regen, then?
