How would you build your music PC today?
Re: How would you build your music PC today?
sima66 wrote:
Sligolad wrote:Pretty much ready to go, just connect it up like shown on his website and forget about it.
Thanks Pearse,
When I looked at PPA page I thought that the separate module clock is only if you buy the clock separately! I somehow assumed that the mobo with clock that he sales is one piece......maybe because I watched Nigel doing it! :)
Paul recommends, on his site, his 5V PS for clock module! Isn't the clock at 3.3v??!
under the hood of ppa clock there is a regulator to make 3.3v
there is a chance it will work at 3.3v also and definitely worth a try
nige2000 wrote: under the hood of ppa clock there is a regulator to make 3.3v
Thanks Nigel,
I was under the assumption that this mobo/clock will use the 3.3v!
I better ask Paul that question.
EDIT:
This is Paul's very fast answer: "My clock module accept +5V only,"
i have one here ill test it with 3.3v but i think it works
nige2000 wrote:i have one here ill test it with 3.3v but i think it works
I hope to, because that will screw all my plans of adapting my battery PS to 3.3v only!
sebna
Post by sebna »
To use a direct 3.3v you would have to skip PPA hand wielded silver step-down transformer which he puts on all his inventions ;) unless I am mistaken in which case I am sure someone will correct me :)
Nope its the clock signal that goes through the transformer
Does that means that I'm stuck with 5v?
Seb, since you have the same clock, how are you powering? From mobo, or diferent way.....5v?
When attach the motherboard to the earthed box, is it better to use conductive material (metal) for spacers, or something non-conductive (wood, plastic)?
I'm thinking brass or ebony.....depending on the answer.
sima66 wrote:When attach the motherboard to the earthed box, is it better to use conductive material (metal) for spacers, or something non-conductive (wood, plastic)?
Please anyone.....would that make any ground difference or any other trouble or benefit?
do you have earth wire in your house power sockets?
is your dac, amps earthed to the wall sockets?
youve got that tellus earth thingy?
