Blind Testing discussion - split from Quad Lamp7 thread
Re: Blind Testing discussion - split from Quad Lamp7 thread
Diapason wrote:
nige2000 wrote: only reason i suggest it is because i believe the differences are large enough not to require exact level matching or long term listening
I know you don't want to get into science here, but this is a good example of the problem with these discussions! You have stated yourself that this test is predicated on your (personal) belief that the differences are large enough. To be honest, that renders the test pretty much useless, since if we're going to start by assuming exactly that which we're trying to prove, there's no point in doing the test at all.
If I take the opposing point of view (that the items all sound identically the same) then if people hear differences/have preferences I can easily claim that it's due to different levels. And so we go on and on and on as people on the internet have always done.
Part of the problem is that the opposing sides disagree on what's "self-evident".
Ok, let's treat both of these positions as biases - Nige's that these devices are easily identified & yours that they sound the same. Isn't the blind part of Nige's test going to eliminate his bias by removing the knowledge of which device is playing & then having to nominate the device he thinks it is. Your bias can't be eliminated in any equivalent way - if you think they will sound the same they will probably sound the same irrespective of the ACTUAL differences between the devices. In other words you would report false negatives
That's one of the reasons why I would like to see a control for false negatives in blind tests as I suspect a lot of such tests are full of such false negatives.
I brought up this issue of controls for false negatives on Hydrogen Audio & couldn't believe the responses - very revealing of the agenda. I brought it up for the reasons I already gave but also because this guy Arnie Kreuger (who claims to be the originator of ABX tests) produced some ABX test results showing a null overall result i.e no better than guessing. He posted the log from the ABX test which shows time & result for each trial among other info. The problem with the results was that I & another guy (Amir) picked up on the fact that in the majority of the trials he had taken 3 second or less to listen & register his choice We quesried this as having done some ABX tests myself I knew this was not a reasonable time to listen to a snippet of X & decide which it was A or B & click the relevant on-screen button using the mouse - in some instances he took 1 sec, in some more he took 2 secs & in others he took 3 secs.
Anyway, when he was queried on this he had some lame excuse that he had mistakenly deleted the original log & this was just a repeat of it. He never said any of this when he first posted the test, ony when he was queried about the speed of the results. He then said in the original ABX test (the one for which he had deleted the log) he had done a long listen & score no better than chance so this was just a repeat.
I suggested that his test results were invalid & that he had not listened to the files, he just selected randomly. This was a great example of why controls like I suggested were needed in such tests as we had no way of knowing if someone was just randomly selecting without listening - it was ony the timing that alerted us to this fact.
So here's the bit that stuns - a number of well known posters including a moderator posted to the effect that if you don't hear a difference in the first couple of trials why would you be bothered to listen for the next 10 or so trials (16 trials is the default I think) - their reason was that life was too short. This is from the guy who claims he created ABX testing & from the Hydrogen Audio crowd - the home of so-called objectivists. In other words they are quite happy with the results as long as the results are null ie no difference heard.
The opposite side of this is that guy I mentioned Amir has produced many positive ABX results showing that he can differentiate between high-res & RB. I know, so what :) but this is another sacrosanct area for objectivists & they have been claiming blind tests have never shown anybody able to differentiate. So when Amir produced his results & did them a number of times following the stipulations & suggestions of these objectivists, failing to find any flaw in his approach or procedure that could explain this positive results they finally settled on accusing him of dishonesty & that his results were not acceptable unless the test was overseen by a trusted 3rd party. This guy, Amir, btw, was a vice-president in Microsft in charge of the audio production side of things so is well trained in both running blind tests & hearing distortions & he also considers himself an objectivist
So, it really is interesting to see the reactions of these people when faced with evidence that they have been demanding for years & nobody producing it& finally when positive evidence is produced they then go into a tizzy of denial (the Foobar ABX software plug-in even had an update to make it more difficult to cheat it).
So all of this made me even more convinced that blind test results needed some internal checks to record how prone the test/tester is in producing false negatives.
Just to be clear, Diapson, I'm not putting you in the same category as these Hydrogen Audio guys but your bias in this instance would likely produce no difference. The only way to tease this out is to have some internal, hidden controls that have known, agreed differences & if they are not picked up as different then the tester is biased to not hear differences or he is tired & lost focus or the playback system is not revealing enough or ........ in the case of the HA guys they have monkeys sitting in for them to do the test because life is too short :)
BTW, I can't remember if I posted this here before but some examples of an area of auditory perception that I think holds the greatest promise of advancing our understanding - Auditory Scene Analysis (ASA)
Some examples I gave before but may be worth repeating:
- this one is a demonstration of how a tone buried in noise can be revealed by having another accompanying sound that is modulating in synchrony with the buried tone - Try it here for yourself http://auditoryneuroscience.com/topics/ ... ng-release
- another on to try but this is more to do with music - it is two african xylophone players (I'm sure it would work with steel drums too) that when listened to individually sounds completely different to when they are intermingled - it's an example of how our auditory perception forms patterns & auditory streams http://webpages.mcgill.ca/staff/Group2/ ... rack07.mp3
Re: Quad-Lampizator7 evening
jkeny wrote:I wonder can an easy script be done which would randomly & seamlessly flip between different playback software while also recording your choice against which pb software was used?
Surely some of the software gurus from the CA section could put something together very quickly. I have some Python skills but I've no idea how the likes of MQN are launched/shut down etc. Can Jplay be run in command line mode? I dont have CA in my system so unfortunately I cant say. In time, the script could include all sorts of hidden control trickery if the listener wanted to push things a bit more.
Again, the key is to allow a person to do this kinda of thing in their own relaxed environment over a period of time. The comparison of the software players is the easier test to begin with and involves the least amount of effort for the listener. Applying the above to amps etc would be a lot more challenging.
John, you might be a very knowledgeable guy, but you are also a very bad businessman.............or advertiser!
This theory of "all sound the same (or similar)" is the theory that you should gratefully embrace and spread when sale your equipment!
Since you looking for a box for your next project, I would advise to find the most "shiny" one (with big WAF), no need to change anything from the previous Ciunas and put the price tag of at list $5000 .........or more (if the box is super shiny)!
You should use slogan like: "Better than DCS, but only for a fraction of the price! Blind test available......bring your DCS with you"!
John has said it above, but I feel compelled to point it out again: I'm not one of those objectionable objectivists. I don't have a side here and I've no interest in taking sides. Like everyone I have my biases, but I'm not going to be the cheering section for the everything-sounds-the-same-and-all-we-really-need-are-oscilloscopes brigade.
sima66 wrote:John, you might be a very knowledgeable guy, but you are also a very bad businessman.............or advertiser!
Haha sima66 - thanks but I was told to use the slogan "Better than the Diverter but......." :)
Diapason wrote:John has said it above, but I feel compelled to point it out again: I'm not one of those objectionable objectivists. I don't have a side here and I've no interest in taking sides. Like everyone I have my biases, but I'm not going to be the cheering section for the everything-sounds-the-same-and-all-we-really-need-are-oscilloscopes brigade.
I know you are not in that league but I thought it worth pointing out what is out there. If anyone wants to read the HA thread:
http://www.hydrogenaud.io/forums/index. ... t&p=887308
who would have thought i op'd a blind testing thread
i usually avoid like the plague
think it gets far more complicated than it needs to be
sonicweld diverter is very shiny, just as well it does a good job too
when dac manufacturers got the memo to put a €5 dac in a €500 box, i think someone misunderstood
nige2000 wrote:who would have thought i op'd a blind testing thread
You got in before me.Eating breakfast this morning the irony of it struck me.
Can I suggest you change your name to Nulf at least on this thread?
