tony wrote:Nigel when he is back online will deal with this much better than I can.
The mobo clocks seem to be relatively cheap (crystal)couple of euro each. I am sure Nigel checks out whatever the spec is for these clocks and matches them. The Pang card v3 has a ocxo clock and these are expensive.
All of us including Nigel I think favour(or recognise) the pang card(V1) brings an extra body (weight) to the sound.
nope not just that cheap usually under 10 euro plus shipping
but there small and easy lost if dropped and there is some wastage as you always buy spares just incase :)
i think the pang v2 card we tested adds weight as maybe a sort of flavouring which may or may not suit certain tracks overall i prefer my card due to its more revealing nature and a sort of delicate sophistication as well as a lower noise floor
there was one anomaly though and it still has me puzzled, my card didn't sound proportionally as good on tonys pc as it did on pearses pc on which it really shone, anyway more testing required we shall get to the bottom of it yet
after my audio voodoo training i will be trying out some anti-vibration on the usb chip which could possibly lead to a more solid sound
Nigels clock in my opinion was not necessarily thinner sounding but maybe edgier in sound. Is this design/noise etc don't think Nigel knows yet. The oven clock thing Pang is doing seems to do something very positive also and Nigel will have to answer whether his can get to that level without the cost.
His card is cost effective especially if doing it yourself.
id be inclined to ask ppang to send you a clock he could be as cheap a source as any
though it seems to require 5v+
My board is standard no clocks but I currently have a Nigeboard(test one) on loan and he has soldered up two clocks. Will test that over xmas but haven't chanced connecting it up until I revert to Nigel to make sure I do not blow it up. It is semi set up but still needs + and ground to be connected up to it.
I think Pearse has a board with ocxo clock installed either on the way or maybe he used it last time!!
If that turns out to be great sounding can't see Nigel coming up with a cheap clock version to beat it but
all Nigels work to date on mobo's have yielded excellent results. Ignoring all the expensive stuff and just following the basic Nige formula gets you most of the way. The eureka special sound from my experience always costs lots of bucks
well im back now so ask away
