rickmcinnis wrote:What does the line to the right of the XO signify? Think I figured it out it - it is the DATA + line - I guess we can presume the DATA - point?nige2000 wrote:ok this is based on a silverstone EC01-P
because its simple less is more etc etc
and the siliverstones well regarded over at xxhighend
its better than the rear mobo port oob thats always a good start!
right theres 3 pins on this pcie slot that need to be covered/taped up,
believe it or not theres still noise on my pc apparently as it wasn't enough to power the new clock with a lifepo4 (which did provide the vast majority of the sq lift) but there was extra benefit of powering the usb chip from the lifepo4 too,
and ill take it all thanks very much
What do you mean by the noise comment? Did you mean you need to use two batteries - one for the clock and another for the USB chip? Or what?
Thanks.
AUDIO PC: THE USB CARD
Re: AUDIO PC: THE USB CARD
nope thats the 5v from molex
one cell will do both usbchip and xo
Can you recommend an oscillator?
I will keep looking for the USB outputs!
rickmcinnis wrote:Can you recommend an oscillator?
I did suggest an xo on page 4
Which USB card did you get?
On this one you have to tap into the d+ and d- after removing the 21 pin header
Which will be likely impossible without hot air or the likes
Well, I started a new OS install and thought I would install the USB card while I could.
The damned installer needs some JAVA junk to install! How ridiculous.
Are there other ways of getting these drivers, even though the drivers I have are listed as RENASAS (doubt I spelled that correctly) in DEVICE MANAGER - is there a difference in these drivers even though they are branded the same (well, the MS name is tacked on to the ones in my system)?
I have a heat gun and learned to use it removing video and audio chips from MBs. In the JULI@ days we removed all of the USB power supply stuff, too. That might still be of use, now that I think about it. Power the mouse and keyboard remotely ... Save some wear and tear on those batteries.
If Microsoft is tagged to them in device manager they are Microsoft drivers needs to say nec or something else
you can just install the inf file surely
Do you remember needing JAVA for installation?
What is nec?
My standard drivers are listed as Renesas USB 3 something Microsoft at the end. From memory.
Will try manual since I have no choice at this point.
Got some of the small A123s for the p24 12 volts rail, finally. Ready to go with battery power.
What is nec?
Nige2000,
What do you use to get your 5 volts battery pack to 5 volts before connecting to the float charger?
Thanks,
Thanks,
car bulb ;)
I assume anything other than a headlight bulb?
