OS for playback software on (Windows 7 or Windows 8)
Re: OS for playback software on (Windows 7 or Windows 8)
nige2000 wrote:4gb works 6gb sounds better
8gb to be sure, to be sure
I find with 6gb you get away with it most of the time but if you play a selection of hires files together you can get white noise through the speakers i.e. it crashes at some point. It just requires exiting jplaymini and start playing again. Thats 6gb on control pc I am sure the same logic or similar applies to single pc/laptop.
Peter Stockwell
Post by Peter Stockwell »
OK, I'll be getting some more RAM, then, innit. Having a bit of a battle with windows 7 making my thumb drive bootable for Windows server, but I think I'm getting there.
You have to be a bit of a nerd to go this far, must be why people like Macs. Apple won't let you be a nerd, just a fashion victim ;)
Just had a thought, can I run windows server on my mac mini ?
Cubox-i2/Volumio/Meridan G68ADV/2 x Amptastic mini-1/Custom Hifi Cables DC3 psu/Audium Comp 5
im not even sure the pc has to be turned on for mqn
its very easy on resources
yes server should work on the mini whats the model till i check
did a bit of tinkering with macs too
if you need help making the windows to go usb key give me a shout
Peter Stockwell
nige2000 wrote:im not even sure the pc has to be turned on for mqn
Hi Nigel,
Was easy in the end, I just needed bootsect.exe in the same directory as Windows 7 make USB/DVD iso whatsit.
It's a 2006 core duo mini, mind you only 2Gb of Ram, wont take more and it's 32 bit, so it won't work.
Hi Nigel,
what ram is in the nuc?
Peter Stockwell
4Gb in the NUC.
Peter Stockwell wrote:4Gb in the NUC.
Dont think jk has any more ram than 4 gb in his
didnt hear about if any issues with that
my experience was 4 gb was plenty for ultrastream mode in jplay.but with 6gb had a nicer tone to it
If you badly need it Peter extra ram will not be more than 25-35 euro depending on type. Just make sure you have a spare slot or maybe just swap a 2 for 4 if your machine will recognise that. Use a memory configurator to confirm the max ram
Has anyone a link to the MQN files..The seem to have disappeared from Rapidshare...
jadarin wrote:Has anyone a link to the MQN files..The seem to have disappeared from Rapidshare...
http://mqnplayer.blogspot.co.uk/
