a bit more mucking about with registers and we get 3.55, think will stop there for a while, sounds ok
darkpink
Post by darkpink »
Thank you Gordon, 3.53 sound fantastic! Can't find .55
Fujak
Post by Fujak »
darkpink wrote:You who use a headless system, what software do you use with MQn?
I guess you mean software for remote controlling. Well, I use TightVNC-Server on my headless PC, remoting it by a Android tablet.
This works without affecting SQ.
darkpink wrote:Thank you Gordon, 3.53 sound fantastic! Can't find .55
3.56 there now, have a good weekend
after a few tracks, 3.56 sounds very good, music sounds as it should.
uploaded an avx version
jorm
Post by jorm »
Sbgk, FYI 3.56 avx is another kazoo version with Audiophilleo and thesycon 2.20 .It played normally initially with M2Tech Young,but then distorted on the second attempt.That´s both with and without Tasker .
darkpink
Post by darkpink »
jorm wrote:Sbgk, FYI 3.56 avx is another kazoo version with Audiophilleo and thesycon 2.20 .It played normally initially with M2Tech Young,but then distorted on the second attempt.That´s both with and without Tasker .
same here
Really need to get avx going again
Debug or whatever
Best pony stuck in the stables
Unfortunate
nige2000 wrote:Really need to get avx going again
Debug or whatever
Unfortunate
3.56 avx almost works. distorted robot sound.
agree!
all things ok. little things are better. musicality especially vocal feels like another level
3.3x, 3.4x, 3.5x has superior performance over all software. mean it.
the sound is light, flows like feathers, i don't feel any digital weight.
i have tones of things running. doesn't sound as though they exist at all.
e.g. intel graphic driver makes sound fatter, heavier. recent mqn versions sound as though it is not there.
