Okay,
first Snow Leo with Amarra, Pure Music etc.
Then JPlay/Streamermode Win 7/8.
Then JPlay/Streamermode and Win Server 2012/Optimizer.
Now MQn.
don't know if it matters, think MQn proves to some extent that less code/cpu proceesing is betternige2000 wrote:I'd image other software playersKarl wrote:Hello Gordon,
do you mean other MQn play.exe or other softwareplayers?what other players have you tried ?
Karl
JPlay xxhighend etc
No indeed it is not comparable to anything.nige2000 wrote:Listening to 3.39 v2 Avx
Strange thing
Don't think it's comparable to anything
Then again could be the just the stress of Sunday shopping
Exciting
It sounds on my setup as if the piano is played on a kazoo (for those not familiar with a kazoo http://en.wikipedia.org/wiki/Kazoo ).
The previous 3.39 avx sounded just fine, so I don't know what happened to V2 but it went wrong somewhere.
sbgk wrote:what does it make a kazoo sound like ?
did you check the wiki ? :-)
it sounds like humming through sigaret paper tightened across a comb (a cheap way of creating your own kazoo from my youth) :-)
it is a kind of metallic humming sound but with the music recognisable.
cheers
Avx up to usual anticsAleg wrote:No indeed it is not comparable to anything.nige2000 wrote:Listening to 3.39 v2 Avx
Strange thing
Exciting
Some sort of incapability with tasker
Try without
Will need to be fixed
Not with me, running without tasker doesn't make a difference neither does rebooting or starting it with mqnload instead of mqn.batnige2000 wrote:Avx up to usual anticsAleg wrote:No indeed it is not comparable to anything.nige2000 wrote:Listening to 3.39 v2 Avx
Strange thing
Exciting
Try without
Something appears to have changed in the avx V2 that doesn't suit my driver/ddc
Sounded great played oob
Didn't have tasker going
Certainly didn't sound bad
Applied tasker getting problems with and without now
Must be another bug
Must be another bug
What version is working for you guys? Obviously the kazoo version works grand for me with Talking Heads it all sounds great!
I am using 3.39avx no pre. When I had a look a few minutes ago there are so many versions of 3.39avx I just gave up.
3.39sse2 and the avx no pre sound excellent for me.
