2channelaudio wrote:thanks all sorted
set files in compatibility mode to run as administrator.
thanks Aleg
2channel
Just to explain.
The latest mqncontrol.exe (the one from the 2.97.zip package) can handle multiple sample rates by itself.
Therefore we now have mqnplay1644.exe and mqnplay2496.exe which will be used for each of those sample rates.
What now happens is that this new mqncontrol.exe will check what sample rate the music files have. It will then copy the mqnplay1644.exe or mqn2496.exe or other, according to the sample rate found in the music files, to mqnplay.exe and run that mqnplay.exe with your music files.
Mqncontrol therefore needs autorisation to copy and overwrite the mqnplay.exe
cheers
aleg
2channelaudio
Post by 2channelaudio »
thanks Aleg
2channel
Just to explain.
cheers
aleg
Thanks Aleg I thought something must have changed
I'll be sure to grab the mqncontrol file from the 2.97 zip package
The MQn read me needs an update
Thanks again
Thanks again
im sure youve figured out by now why no-one wanted to do the mqn read me
my CPU has no AVX2
with my CPU, 3.37 sse is almost equavalent in music flow to 3.27 AVX. probably better
detail is 3% to 10% higher > 3.27AVX
emotion is kept, and more natural.
3.27 AVX has very slight digital intensity
i am sure AVX2 version will be god like... need a new mobo new haswell coming this summer
how about a sse4.1 version?
to me, this 3.37 is a reference version (last reference is 3.27)
3daudio
Post by 3daudio »
@ Jorgen
Thanks for your input. My CPU only has sse2, no avx here for the moment, My WsR2 is setup as admin in MInimal Server Mode.
I will try your suggested tips eventually, but today my new DDC arrived with which I can listen to all the 16/44.1 versions and don't have to wait for a 24/44.1 versions from Gorden.
Beat you to it, Gordon. -:;))
Regards
wow 3.37 is getting better by the minute!
texture increases by 2-3% by restoring affinity to untweaked
realtime priority adds 4-5% refinements to micro-details
usually when i do such thing, SQ goes south for MQn.
this is really really really good
3.38 maybe a bit better balance, was losing some detail with 3.37, same code just 2 instructions swapped place
add r14, r13
sub r9, r13
instead of
sub r9, r13
add r14, r13
explain that one, instructions taking different times to get to the cpu ?, take different times to run ? Anyway the effect is audible.
yes 3.38 maybe better
more emotion focus.
with 3.37 i feel zero intensity. maybe too neutral. (what digital setup doesn't have intensity??!)
need time to tell which is better
JC, there's an interesting debate about mmcss settings and whether they change only at mmcss service start, I think they do, but I'm sure we've all thought there was a sound difference after changing them via regedit without restart.
the solution seems to be to have a proaudio setting for each bitrate sample rate combo eg pa1644 etc
sbgk wrote:JC, there's an interesting debate about mmcss settings and whether they change only at mmcss service start, I think they do, but I'm sure we've all thought there was a sound difference after changing them via regedit without restart.
yes. changing registry in mmcss is effective immediately. realtime settings
from time to time i retest each values in mmcss. i cannot do better than pkshan's mmcss registry.
funny he figured this out years ago before win8 existed. total respect.
same mmcss applies from win7 to win8.1. nothing really has changed in windows. apart from graphical rendering.
if you believe me, i think clockrate needs to be discovered depending what DAC one got.
in reality, for pa1644,there is only 2 clockrates that perfectly syn the timerresolution
640=14.5ms. and 352=8ms
448=10ms but the rounding error is big, you can detect little lost of res.
default clockrate doesn't sound that bad.
incorrect clockrate will sound really wrong.
