3.34
DJ le Roi
Post by DJ le Roi »
I think 3.34 is beautiful, extremely detailed in my setup. I hear details which I never heard before. Thanks!
Clive
Post by Clive »
I'm trying to not to compare too many versions as who knows when Windows will strike down my capability to play MQn. I have loaded 3.34 SSE2 successfully at the 1st attempt. I've compared to 3.27 AVX. I find the balance between them different, SSE2 being a little richer, smoother vocals, slightly fuller bass with hi-hats not quite as prominent. It's hard to say which version I prefer and I'm sure my view would differ according to the system used.
3.35 has the fewest instructions
madman6000
Re: batch file doesn't work
Post by madman6000 »
Clive wrote:
madman6000 wrote: OK got sse2 working by selecting the dac as the default sound device. My CPU is i5-2430M should this work with avx because it doesn't seem to. The processor seems to have avx instruction support but not avx2. I wasn't able to determine from this thread which is required.
Hi Madman (Adam?), which edition of 8.1 do you have? Mine is just 8.1 (used to be be Home under W7. It seems Pro and Enterprise have a different and more reliable way to run in elevated mode. My i5 is an Ivy Bridge and only support AVX, not AVX2 and it works...mostly! I just put 3.33 SSE2 on today which didn't work at first. I had to reset EnableLUA in the registry. This was after running 3.27 AVX all day yesterday (including a couple of reboots) without one problem. If I change a file in the mqn directory it leaves me with a non-working mqn. It's some Windows peculiarity with admin files IMO. BTW you should try Aleg's Tasker, it makes a big difference and is not harder to get running and in some ways it's easier.
Clive, yes it's Adam. I have windows 8.1 pro. SSE2 works every time for me but have not heard anything with avx yet, but you say it should work. Not sure what else to do at this point. One thing I've noticed is when the avx version starts the hourglass cursor appears for a split second, then the process proceeds with no sound. Looks like this appears in windows error log:
Log Name: Application
Source: Application Error
Date: 5/8/2014 7:17:06 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: dac
Description:
Faulting application name: mqnplay.exe, version: 0.0.0.0, time stamp: 0x5367ee34
Faulting module name: mqnplay.exe, version: 0.0.0.0, time stamp: 0x5367ee34
Exception code: 0xc0000005
Fault offset: 0x00000000000013bc
Faulting process id: 0x1450
Faulting application start time: 0x01cf6ac82ebbdf30
Faulting application path: C:\mqnavx\mqnplay.exe
Faulting module path: C:\mqnavx\mqnplay.exe
Report Id: 6ed355bf-d6bb-11e3-8250-14dae950a5ec
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2014-05-08T14:17:06.000000000Z" />
<EventRecordID>361</EventRecordID>
<Channel>Application</Channel>
<Computer>dac</Computer>
<Security />
</System>
<EventData>
<Data>mqnplay.exe</Data>
<Data>0.0.0.0</Data>
<Data>5367ee34</Data>
<Data>c0000005</Data>
<Data>00000000000013bc</Data>
<Data>1450</Data>
<Data>01cf6ac82ebbdf30</Data>
<Data>C:\mqnavx\mqnplay.exe</Data>
<Data>6ed355bf-d6bb-11e3-8250-14dae950a5ec</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: dac
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>100</Task>
<Security />
</System>
<EventData>
<Data>1450</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Hi Madman Adam
This is caused by an Access Violation error.
Follow my instructions here to set the security policy right: viewtopic.php?p=55670#p55670
Then follow my instructions here to set the elevation levels checkboxes for mqncontrol.exe and mqnplay1644.exe: http://tirnahifi.org/forum/viewtopic.php?p=55699#p55699
Should work in most situations for Windows 8.1 Pro
madman6000
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: dac
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>100</Task>
<Security />
</System>
<EventData>
<Data>1450</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Hi Madman Adam
Aleg, thanks for your help I've done all that still no dice, getting same error in log.
darkpink
Post by darkpink »
Haven't you red about the avx ritual? :)
Try avx in a new folder and delete the old one, works most of the time.
madman6000
darkpink wrote:Haven't you red about the avx ritual? :)
Fuck me that worked wtf. Thanks for all of your help everyone!
darkpink
Post by darkpink »
Cheers mate!
