----TWEAK 55-----
reduce usb polling rate. (already posted this)
http://blog.sina.com.cn/s/blog_72b3301c0100ph4o.html
i just realize this tweak cancelled itself. i guess it happens after updating/cleaning up drivers.
(spent a month trying to figure what went wrong... it is this little piece of s**t)
start to don't care what anything means anymore. just tweak and test
saw the string "DPI". have to try it
http://cpuoverride.blogspot.com/2014/02 ... -htpc.html
add LogicalDPIOverride with a value of 1 to
HKEY_CURRENT_USER\Control Panel\Desktop\
to cancel
[HKEY_CURRENT_USER\Control Panel\Desktop]
"LogicalDPIOverride"=-
BRIGHT.... hurtful. cancel immediately...
updated
viewtopic.php?f=15&t=2456&p=47296#p47296
saw pkshan updated his list. so i re-tested everything. found two mistakes
cancel disabling these:
(win7 and above)
Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller
(win8 and above)
Remote Desktop Device Redirector Bus
cancel disabling core-parking.
RESTORE TO DEFAULT
powercfg -setacvalueindex scheme_current sub_processor 0cc5b647-c1df-4637-891a-dec35c318583 10
powercfg -setactive scheme_current
DISALBE CORE PARKING
powercfg -setacvalueindex scheme_current sub_processor 0cc5b647-c1df-4637-891a-dec35c318583 100
retested from 0, 10, 20...100:
0 is little messy
10 just sounds right
20 treble starts to turn hard, sharp (by losing micro-details)
100 gets more hard, more sharp, more airy (by losing more micro-details)
100 worked fine for me when OS was poor. now the issue becomes too obvious to ignore.
i use i7. not sure this applies to i3, i5.
(NOTE: FOR GAMERS, disable core-parking is usually a good idea)
internethandle wrote: ........
Anyway, here's the screenshots of what I was able to delete, finally:
Here's the contents of the "drivers" folder:
All told this was about a 1.5 GB reduction.
I'll post an updated SysWoW64 list later, too, which is only about 150MB.
edit: edited for clearer and smaller images, upped to tinypic
edit 2: These NLS files can also be deleted from system32:
internethandle and for those interested in stripping OS:
http://www.analogx.com/contents/downloa ... eeware.htm
i was able to delete 1-2GB of dll using it.
just need few clicks.
(NOTE: THIS ISN'T MEANT FOR BETTER SQ)
R2 has much better timing than R1. R2 has some kind of 'plastic' tune/layer. hopefully, it will be gone...
here comes R2 tweaks.
white/gray>light blue>darker blue>black
dark colors seem bad for SQ. currently using white.
many new things are undocumented, including:
1. set SleepStudyDisabled=1. i immediately like it
2. in bcdedit, it has this:
allowedinmemorysettings 0x15000075
don't know what it is. deleted it. SQ seemed worse. keeping it for now
3. DisableAutoBoost. default=1. set it to 0. hmm... a lot has changed. not sure
4. MaximumSharedReadyQueueSize. default=1
0 -> seems more raw. 4 -> worse?. 16 -> bad.
again. not sure.
MS has changed default value of LargeSystemCache to 1.
it was 0 in win7/8.
changed it back to 0. now R2 sounds less strain/stretch. lighter. just like R1.
CANCELLED tweak 12 viewtopic.php?f=15&t=2456&p=47527#p47527
default settings best for R2
retesting some old tweaks. no luck. not better.
Powercfg -setacvalueindex scheme_current sub_processor DISTRIBUTEUTIL 0
Powercfg -setactive scheme_current
scroll to bottom of page for explain:
http://msdn.microsoft.com/en-us/library ... e/dn567635
