It's not so gas - wink :)
jkeny wrote:It's not so gas - wink :)
ooookkkkk
cvrle59 wrote:To: jesuscheung
I am wondering if those optimizations in that .bat you just posted could cause some serious issues with some other functionality on a computer.
I do not have (for now) a dedicated computer to play music only, and I am concern if I run those it may screw my computer bad, I mean to make it "dedicated music player only".
What OS are they for, any limits there?
Any experience?
which one of the commands you think will cause issue? i already removed those i tried and disliked.
if you break your face with this script, go blame thinkspace/JIE. he made it. i only modded it.
as far as i can tell, the script gives up security/compatibility in exchange for better SQ. if worry, don't do it.
i have no issue. i wouldn't really know if there is, i don't have virus scan nor firewall
Is there a reverse script?
cvrle59
Post by cvrle59 »
No worries, I do understand that anything we do is own risk.
I just asked if you experienced something really bad to be prepared for.
Thanks for your input!
cvrle59
Post by cvrle59 »
tony wrote:Is there a reverse script?
That would be nice.
no.
cvrle59 wrote:No worries, I do understand that anything we do is own risk.
i have had no bad experience.
lekt
Post by lekt »
hi jesuscheung & everyone,
thanks a lot for jesuscheung's help joining tirnahifi.org.
will be happy with new MQn from SBGK.
sbgk. if i uncheck
"Allow applications to take exclusive control of this device" in "Speakers Properties",
MQn doesn't play. possible to fix it?
coz need music while gaming or streaming on twitch...
