tony wrote:
Aleg wrote:
tony wrote:Is that the same with sse2 Aleg? I found 3.11 ok last night. I had felt like what some of the others are reporting on the early 3.xx versions but I thought things had got better.
OK, it's finished.
I only did the sse2 3.11
I don't think the sse2 is bad, but just not as good as the best of the avx like the 3.08.
For those having problems with running the avx versions, make sure you have the checkbox "Run as Administrator". Set in the properties/compatibility tab of both mqncontrol.exe and the mqn1644.exe.
Also always try to run it at least twice when changing over from another version, I need to do that as well sometimes.
But checkbox "Run as Administrator" is mandatory for me otherwise it will start but no sound comes.
.Back to listening avx 3.08 (and some more Art Blakey ;-))
Good glad your findings on 3.11 are similar to mine. Are you creating false hope here on avx? No Haswell no avx?
Tony
Not all is lost. Your Sandybridge also supports avx
CPUs with AVX:
Intel:
Sandy Bridge processor, Q1 2011[6]
Sandy Bridge E processor, Q4 2011[7]
Ivy Bridge processor, Q1 2012
Ivy Bridge E processor, Q3 2013
Haswell processor, Q2 2013
Broadwell processor, expected in 2014
AMD:
Bulldozer-based processor, Q4 2011[8]
Piledriver-based processor, Q4 2012[9]
Steamroller-based processor, Q1 2014
Excavator-based processor, expected in 2015
Jaguar-based processor
It's the avx-2 that is supported only by Haswell, but I thought Gordon was no longer using specific avx-2 but just the avx.
tony wrote:
OK, it's finished.
What you mean Tony by "No Haswell no avx"?! You can play avx with your Zuma, right?
Ok will go off and try again. I had given up on any avx stuff as I went through a time when nothing worked but will try the run with admin rights and running it twice and see what happens.
cvrle59
Post by cvrle59 »
tony wrote:Ok will go off and try again. I had given up on any avx stuff as I went through a time when nothing worked but will try the run with admin rights and running it twice and see what happens.
I had the same problem, until I checked to Run as administrator and checked Compatibility mode to Windows 8 (control program).
Think I am starting to get like the goldfish going round in the bowl! I remember a conversation similar to this and cvrcle59 comments above but I am using 2012R2. What control is being used with 3.08 avx? Will try that one.
We have the same PC, so it have to work.
None of the avx2 worked, but it should be no problem with avx at all.
I use control 1024.
darkpink
Post by darkpink »
Just got 3.08 avx running on a new ws2012 install one time but after a reboot no go. Tried the checking the mqncontrol-mqnplay-mqnload as admin, win8 compability mode on mqnplay, tried running it more then twice, but still no go. What's wrong with avx, sse always works.
3.14 is there or thereabouts for me
darkpink
Post by darkpink »
sbgk wrote:3.14 is there or thereabouts for me
That one is excellent, just listened to it on low vol because our babygirl is sleeping, the first time I just was listening to the whole ttrack and forgot to analyze. Thumbs up from me
s.nickols
Post by s.nickols »
Aleg - Would you be so kind to share which control you have been using with testing the latest avx 3.08, 3.09, 3.10, & 3.11 versions?
With my set-up (converter is built for 16/44100 only) I've been somewhat in sync with your results, the avx versions have been consistently one small notch above their sse2 counterparts.
I may be the Lone Ranger on this build example, but last night I had good results with avx 3.11 version using the control that was included/packaged within the 2.97 zip file version. For some reason I assumed the control contained within the zip file examples was to be the preferred control for these latest versions. I briefly listened to avx 3.11 with the current posted "control 1024" but preferred the control included within the above-referenced zip file.
I would like to try the same control you are using to see if their is any additional coincidences with our listening results.
Thanks, Steve
DELL Laptop with SSD & I5x4200U, Windows 8.1-UD#1, AR-T Legato USB-SPDIF Converter (16/44100 only), Resolution Audio Opus 21 CD/DAC (GNSC Mods), RA Opus 30 Amp, Harbeth Monitor 30, REL B2 Sub, DSPeaker 8033c Anti-Mode Sub EQ, AR-T & DNM Cabling
