I tried only the latest AVX versions.
The avx 3.09 is my favourite so far. The best bass I ever heard or could imagine! Better definition that any of other avx's. Every note is more pronunciated and separated.
The avx 3.11 has a bit more body, but everything else I like better in the avx 3.09.
Please give a good try to this version!
yes yes. 3.09 is superb. sse or avx doesn't matter here. only subtle differences.sima66 wrote:I tried only the latest AVX versions.
flow, details, balance, bass control, vocal depth, weight... all well done.
listening a bit more...
if listening at really close distance with headphones, then 3.09 sse easily wins. sse has free sounding.
3.09 avx micro details is more 'together', maybe overly together. constant reminder of digital intensity.
3.09 avx flow and focus is forever better.
sse flow and focus is almost as good, not quite.
haven't tried 3.08 nor 3.11. don't think i need to! 3.09 is that good
alright, now comes 3.11....
3.11 sse has more natural stage better focus/flow than 3.09 sse.
but 3.09 has less intensity more free sound.
prefer 3.09
EDIT
prefer 3.09 sse and 3.11 avx because they feel less intense more free
EDIT2
now compare to some older mqn. new mqn is a little aggressive sounding.
apart from that, new is better than old.
prefer 3.09
EDIT
EDIT2
Call me crazy, but I prefer 2.62 with avx control over 3.11 in whatever combination. All this on 24/96.
Sounds richer, more bass extension, deeper soundstage, more natural tone.
There you have it! Battle on guys...
just tried 2.62 avx. nice bass. yea, need that natural sound for 3.xx3daudio wrote:Call me crazy, but I prefer 2.62 with avx control over 3.11 in whatever combination. All this on 24/96.
3.09 and 3.11 a little aggressive sounding.
I agree, just tested 3.09 in all combinations. A tad better than 3.11 but still too aggressive in my ears. Very bright and open, but not as natural sounding (take a violin as reference).
I am sure Hells Bells is a good reference too....for something... :-))
Guys I cant seem to find version 2.62 avx in archive.....
What exactly is the file name called.
I would appreciate a steer in the right direction.
I currently use 2.59 as I prefer a more analog tonal sound.... curious to hear
cheers
2CA
cheers
2CA
2CA,
this is the combination. Both are in the Archive.
mqnplay.exe 24 bit sse2 10ms R2.62 win8.1-r2 hirez
mqncontrol.exe 24 bit avx2 v1 100000
Thanks Christoph, I missed the change in location of the converters, will try that this evening.taggart wrote:Yes, impossible to follow! Particularly as I don't know if the latest changes will last for long or not.
Conversion though, should work correctly with the latest mqnload. Have you noticed that I have changed some folders? Ffmpeg.exe and flac.exe now must be stored in Data subfolder and converted files are now automatically stored in Cache subfolder instead of Temp.
I am an MQNLoad convert so definitely do not want to loose its functionality for ease of conversion and playback.
By the way well done on steering AO towards MQN, glad to hear Wasapi playback for MQN is in consideration during development.
Certainly is a great deal of activity on the forum this past week with good results!
Cheers, Pearse.
hey 3daudio, try this really old mqn3daudio wrote:Call me crazy, but I prefer 2.62 with avx control over 3.11 in whatever combination. All this on 24/96.
2.51 sse4 intel rax no zi noaff (24 bit v5) MOD.zip
https://drive.google.com/?usp=folder&au ... 0plZTNGd0E
can play both 16, 24bits
it has bass like 2.62 avx. i love this version. live and musical. natural. vinyl like. i use it for bass.
(think i modded the PE for more bass. forgot what i did. such a long time ago)
