services.reg has all my services.
was: 3.01MB
now: 2.88MB
SQ increases by 0.5-1%.
mainly reduction in jitters.
if delete one key works, delete all keys work!
if delete one key doesn't work, delete all keys don't work!
this will be my rule of thumb from now on.
much much easier than deleting services! some works some don't. headache...
CANCELLING MY PREVIOUS TWEAK ON DELETING SERVICES. UNTIL I KNOW HOW TO DO IT WITHOUT CONSEQUENCES IN SQ. no change in what services should or should not be disabled. 'disabled' sounds different to 'manual' to 'auto'. if in doubt, put on manual or do nothing.
----TWEAK 47----
soundcard xonar STX install guide:
1. download uni xonar
2. choose 'normal'. don't choose 'c-media'
3. when installation asks you 'accept' or not, DON'T ACCEPT.
*you will lose native ASIO as side-effect. however, you will lose all other useless DSP craps. (native ASIO doesn't sound that good anyway. bye)
*SQ becomes a little more stable.
4. if you do 'ACCEPT',
* please disable all related windows startup
* don't use 'hifi' mode as suggested by your STX manual. it sounds like DSP to me. intense sound.
* leave all settings to default.
5. disable all recording features.
6. MOD your driver using my earlier post. install MOD.
----TWEAK 48----
http://forums.mydigitallife.info/thread ... try-Tricks
recommend:
18 - Protokollierung deaktivieren.reg
think i already posted these:
23 - USB Abfrageintervalle ändern.reg
24 - Überflüssige NTFS-Dateizugriffe ausschalten
https://gist.github.com/Cromm/5531193
makes sense to the zero
"TimeStampInterval"=dword:00000000
this one should but doesn't work. 1 as default sounds best. 0 is not good. 100000 is not good. doesn't make no sense.
quote:
TimeStampInterval
Registry path
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Reliability\
Version
Windows Server 2003 and Windows 2000.
This key defines how often LastAliveStamp (or heartbeat) is written to the registry. By default it is written every minute in Windows Server 2003 and every five minutes in Windows 2000.
----TWEAK 49----
cleaning all event logs from OS
1. open powershell as admin
2. copy and paste below line into powershell:
wevtutil el | foreach { wevtutil cl $_ }
3. press enter.
0.1% boost in SQ.
internethandle
Post by internethandle »
Am I missing something here, or does the poster on mydigitallife list the same two keys for both the USB polling and the NTFS tweak?:
- Change usb query intervals
By default, Windows 7 queries the USB ports every millisecond. In some cases this short checkinginvertal prevents that the PC and especially the notebook can't go into standby mode. This lets 7 check every 5 milliseconds instead of 1ms.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{36FC9E60-C465-11CF-8056-444553540000}\0000]
"IdleEnable"=dword:00000001
- Turns unnecessary NTFS-File accessing off
The NT-file access creates for each file and folder stamps with information about the last access occurred. To save computing time, this feature will be turned off.
That are the tweaks in *.reg files, but there are more tricks in the PDF-files that are very interesting.
Otherwise, nice tweaks, JC. Am still catching up with you with registry slimming, though... ugh.
internethandle wrote: Otherwise, nice tweaks, JC. Am still catching up with you with registry slimming, though... ugh.
difficult to a b compare with registry slimming... need spend a day or two with help of hyper-v or vmware
pkshan updated his reClock mod to XS mod 01Y
http://blog.sina.com.cn/s/blog_72b3301c0100v1xj.html
must update if you had previous version installed. previous version makes sound not free in certain frequency ranges. been bothering me for a long time. i didn't know it causes it.
1 download original reclock 1.8.8.3 (also recently updated)
2. overwrite original with mod files
3. follow instructions to setup
also there is new xa1070a. same sound. more correct.
heard people having audio issue with xbox
fix
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Audio
"DisableProtectedAudioDG" = dword:00000001
some changes in SQ. not sure better or worse
seems that cannot touch
[HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\Display\igfxcui\Media]
"EnableSTE"=dword:00000001
"EnableACE"=dword:00000001
disabling STE and ACE makes sphere shape into box shape so edges feel fat+slow. incorrect
