cvrle59
Post by cvrle59 »
"Julf - When your CA membership was reinstated you agreed not to engage in unprofessional behavior. Based on a review of your posts since that time I believe you've violated that agreement. A warning simply doesn't go far enough. I've decided to ban you from the CA forums for good."
LOL
Clive101
Post by Clive101 »
nige2000 wrote:theres this other player http://code.google.com/p/bitspersamplec ... ayPcmWinEn
that lets you select the output format
can you see which formats work for you
Hi nige2000
Have installed this and when I play a track it says WASAPI Exclusive 44.1 Khz 24bit 2ch PCM
No other formats in the
Regards
Clive
Is that the problem 24bit??
Clive101
Post by Clive101 »
cvrle59 wrote:Clive
Have you tried to unplug USB cable and play it on your computer audio only?
That would help in troubleshooting somehow, to make sure if problem is in your computer only, or computer and DAC don't "understand" each other.
Hi cvrle59
Thanks for the suggestion - I think the setup is OK as I play ok using JRIVER.
Regards
Clive
cvrle59
Post by cvrle59 »
Clive101 wrote:
cvrle59 wrote:Clive
Hi cvrle59
Regards
Clive
I meant MQn set-up. I understand that you can play JRiver, but you should be able to play files with MQn on your computer audio. Versions 2 will have kind of static during play, but you should be able to hear music. If you can't do that, you have some other issues, 24 bit, special characters in the name of the file or something else. You need to isolate those from the computer/DAC communication.
Good Luck!
Clive101 wrote:
sbgk wrote: can you run the wasapi_test program that's in the test folder, needs to be run from a cmd prompt, you list the devices and then list the formats for the selected device, post the results of event on exclusive on section. beware the brackets that look like <> are actually () (if your device name has brackets)
was it you who said the usb was 1.0, don't know if that would affect things as can't do asynch
Hi sbgk
Thank you for your help - here's the output of the Event On Exclusive On section:
EXCLUSIVE: on EVENT DRIVEN: on
32000 24 2 192000 6 65534 22 24 3 - Format works ok
44100 24 2 264600 6 65534 22 24 3 - Format works ok
48000 24 2 288000 6 65534 22 24 3 - Format works ok
88200 24 2 529200 6 65534 22 24 3 - Format works ok
96000 24 2 576000 6 65534 22 24 3 - Format works ok
Regards
Clive
all 24 bit, so no go. am doing a 24 bit version that will have 16/44.1 as well, you need 24 bit for everything, I guess you don't have 24/44.1 music, the 24 bit version does 24/96, you could try that.
cvrle59 wrote:"Julf - When your CA membership was reinstated you agreed not to engage in unprofessional behavior. Based on a review of your posts since that time I believe you've violated that agreement. A warning simply doesn't go far enough. I've decided to ban you from the CA forums for good."
LOL
Julf who ?
He started this thread on slim forums http://forums.slimdevices.com/showthrea ... -get-worse
obviously has some issues that need working on.
Clive101
Post by Clive101 »
sbgk wrote: all 24 bit, so no go. am doing a 24 bit version that will have 16/44.1 as well, you need 24 bit for everything, I guess you don't have 24/44.1 music, the 24 bit version does 24/96, you could try that.
Hi sbgk
Thanks very much for your help.
I've downloaded a version from folder "mqn 24 96 test" from https://www.dropbox.com/sh/tw9i3e9dkky9j6q/Qe7aL08-jF - not sure if it is the 24 bit version you mention but tried to play a 24bit 96 KHz wav fie and got an error saying MQNControl.exe has stopped responding - exception code c0000005.
Regards
Clive
Clive the 24bit one is the one we are all waiting on for dacs that require it for hires.
There is no working version yet SBGK is working on it
SBGK Thanks re info on version. When I get an evening to test out some of the favs will make sure I note the versions if that fails will contact you.
tony wrote:Clive the 24bit one is the one we are all waiting on for dacs that require it for hires.
the 24 bit test version has worked in the past, not come across that error before, shall try and dig out a diagnostic version, it doesn't play, but will give some diagnostic messages.
