NOT QUITE NEVER AGAIN, THE GROUP BUY DAC BUILD
Re: NOT QUITE NEVER AGAIN, THE GROUP BUY DAC BUILD
sounds good... better than i remember
hopefully we can squeeze a bit more out of it with some fine tuning
ITS ALIVE!!
Seriously though - well done Nigel on sorting out the issues with that board and getting her running.
On the relay front - well, we found some premade ones on ebay so we have a couple of different ones coming that will give us some choice.
Great to see it running.
Brilliant to see, Nigel, the excitement grows.
Great work guys....nice to hear music from one of those boards as well.
If you do test the SD player in the case Nige it is already bypassed for 3.3v direct to the power pins.
Picked up 4 x 1kG rolls of Print material from Radionics today so ready for printing what we need.
ok it going on supercaps into onboard regs, luckily sounds better on supercaps than it did on the lifepo4 pack
im quite optimistic about the sq we shall get, shows a lot of promise
havent connected a sd card player yet
for now ill test the ps system.... if it lives til saturday id guess it looks good :)
That is great news Nige with the Supercaps...just noticed my incorrect wiring of the regulators after seeing your picture, glad you went in and caught that!
randytsuch
Post by randytsuch »
What part number supercaps are you using?
Supercaps are on my list of things to try.
Randy
You can find these salvage in China
https://www.google.ie/url?sa=t&source=w ... rq7xmg2cOr
Sligolad wrote: Tue Nov 27, 2018 4:35 pm That is great news Nige with the Supercaps...just noticed my incorrect wiring of the regulators after seeing your picture, glad you went in and caught that!
Lol thought you were trying to catch me out
