Lampizator Big7
Re: Lampizator Big7
its a box:)
Re: Lampizator Big7
Wow sounds like you got a bargain! Congrats! Would love to hear it at some stage maybe compared to the Hugo?
Re: Lampizator Big7
LOL, glad I'm not the only one.Ken Moreland wrote: WTF?
Nerdcave: ...is no more!
Re: Lampizator Big7
How can you say that! it is more than that to me.nige2000 wrote:its a box:)
Re: Lampizator Big7
How about a Pic with the top off Tony to clear up the confusion on "nothing inside".
Mines been topless for some time now waiting on me to start re-wiring the Amanero USB with the silver wire!!!
Are you sure it is a Big7 or are you just teasing :-))
Re: Lampizator Big7
It is just the Big7 case Pearse unfortunately. Couldn't resist but it is a very practical choice. I need a box for my power supply/batteries.This is big enough for the mobo and power supply/batteries. It cost me a good deal less than a streacom fc9 case.
Was going to have to get a case made or buy a ready made one anyway.But now I can use the existing streacom for something else.
Re: Lampizator Big7
Aha! I assume the plan is that you get everybody at home used to the look of the Big 7, so when the real Big 7 makes an appearance nobody will be any the wiser.
You're not as green as you are cabbage-looking* Tony!
*My wife's phrase. Blame her.
Re: Lampizator Big7
Diapason wrote:Aha! I assume the plan is that you get everybody at home used to the look of the Big 7, so when the real Big 7 makes an appearance nobody will be any the wiser.
Well I wish it was as easy as that. The case aint the problem it would be the massive hole in the finances that would scupper that kind of plan.
No this is the ultimate cheap ass subjectivist solution.
Re: Lampizator Big7
tony wrote:Diapason wrote:Aha! I assume the plan is that you get everybody at home used to the look of the Big 7, so when the real Big 7 makes an appearance nobody will be any the wiser.
well wheres the pics?
Re: Lampizator Big7
Hope this is a big enough photo?nige2000 wrote: well wheres the pics?
