Ciaran wrote:I'm afraid I have to apologise for the absence of a coffee break! As so often happens, we were to caught up in the audiogeekery to have time for a break, and the afternoon seemed to fly by very quickly. Thank you all for coming along: it was a great pleasure!
Don't worry, Ciaran, as you said the time flew by without notice.
John had to cope with my classical-only rule: I'd ripped a lot of tracks (losslessly to WAV files) and we were able to compare them with CD replay on the dCS stack.
We also had some hi-rez files we were able to compare with SACD.
Thanks for doing this - classical is not my area of listening as evidenced when asked what track I was playing, all I could say was it was Christmas Mass :)
For me the performance of the JKDAC got much closer to the dCS stack once it was fed hi rez files (24/88.2 or above). We didn't compare any 16/44.1 files via the JKDAC and dCS after John had fixed the 6dB attenuation in his player, so we don't know if that would have made replay at that resolution better or not. We should probably have been more methodical and checked that.
Yes, the volume issue was a real slip up on my part but the day threw up a number of conundrums & the biggest one revolves around why the vol change could make such a difference - it doesn't do this on any other system, I've heard? Ciaran, does your system show this characteristic normally i.e if the system volume is turned down a bit that it loses a lot of attack, dynamics & ambience? This vol issue also seemed to mask the difference between Foobar & Jplay so again it wasn't just a matter of the sound pressure being lower it was masking something! Just to explain again, I had the digital vol set at -6dB which is dropping 1bit off the signal. AFAIK, this shouldn't eat into any resolution of the sound as if playing back 16 bit material using a 24 bit DAC, in theory I should be able to drop 8 bits before I'm effecting the information carrying bits. I need to investigate this further but as I said it does not do this on other systems. Any ideas?
Sligolad wrote:]Did you feed the DCS using Jplay from PC?
No, the dCS was not fed from John's laptop: only from the Verdi la Scala transport or in one case from the Squeezebox Touch, streaming from my computer. The comparisons with the Touch were JKDAC playing the same 24/88.2 file as the Touch and the stack playing the equivalent track from a standard CD. In this case I thought honours were divided about evenly between the JKDAC and the stack, with the Touch objectively fine but subjectively less involving.
Yes, this is the elusive involvement factor - what is it in the sound that gives this? Anyway, I felt the JKDAC & Touch needed A/B listening to sort out, they were that close.
Very interesting! I'm sure there are big strides to be made in computer audio, probably in the short term, but my investigations highlighted for me the dearth of available hi-rez material. I would want to see more of this before I got serious about computer audio.
Yes but I don't think it's only in high-res that computer audio has a role - it is approaching the best of spinning disk playback at any resolution. What the dCs system showed is that 16/44 playback can sound as good as high-res if done with great care & that it really comes down to the recording!
Thanks again Ciaran for affording me the opportunity to have a listen to your wonderful system - it gives me a great benchmark.
