R2.75, let's have another go at saying this is the final version
sbgk wrote:R2.75, let's have another go at saying this is the final version
I like when you say that, because after every of the "final versions", you come up with a better one! ;-)
Can't wait! :)))))
R2.75 is good , now lets have an AVX version in assembly with all sample rates and we'll call it a day.
darkpink
Post by darkpink »
how did u guys get avx working again on r2?
cvrle59
Post by cvrle59 »
I installed new MQnLoad, and I can play only SSE2 versions. I tried R1.4 and R1.5 control with any new avx version, but no luck. I can't even run famous 100000 version any more.
Any idea what could be different from old MQnLoad that causes this kind of issue?
cvrle59 wrote:I installed new MQnLoad, and I can play only SSE2 versions. I tried R1.4 and R1.5 control with any new avx version, but no luck. I can't even run famous 100000 version any more.
Don't think it is related to MQNLoad.
Have these issues sometimes with AVX.
Just keep trying at some point it will run again.
Don't understand what 's causing this.
thisisvv
Post by thisisvv »
thisisvv wrote:
darkpink wrote:
Use mqnplay.exe 24 bit sse2 10ms R2.3 win7 and whatever mqncontrol you like with WIN7 and it will work with that OS, the other ones is for R2 and 8.1.
I just got mqncontrol.exe, mqnplay.exe, mqnload, (Data folder with ffmpeg.exe and flac.exe)
still unable to work...it flashes and then nothing happens
V
still need help on this please
V
darkpink
Post by darkpink »
V
V
Try the next newest mqnload, the new one didn't work on my audiopc (R2) just my desktop (W7), mqn just did a little flash thing then teminated.
V
V
what cpu do you have, needs sse2
sbgk wrote:
V
I never managed to get MQN running when I was using Windows 7 on my Office PC. Upgraded specially to 8.1 to be able to use it on that PC as well. I never found the reason why it wouldn't run on Windows 7.
When the command window flashes momentarily it is probably due to mqnplay.exe crashing. So you could check the Windows event log for the reason of the application crash if it did crash.
That way you could get some better understanding why it is happening.
