thisisvv
Post by thisisvv »
tony wrote:
6 files should be in the folder. Not sure if you are saying you have a copy of a wav file in the same folder but you don't do that.
file names as follows
files
MQN (Bat file)
MQNControl
MQNPLAY
Param
paste
The 'files' folder appears when you copy the music track and double click the mqn file.
Files will just have the name of the track you are playing
Are you renaming the play and control files to mqncontrol.exe and mqnplay.exe?
So just edit the file name and delete the 2.70R1.5 etc etc bit
Right click MQN (Bat) file and check that it is pointing to the right location. Edit the address if not. Make sure you are admin on your pc also.
What operating system are you using?
Param.txt shows the filename i am trying to copy....i am using windows 7 pro on I7.....attached screenshot shows the files...unable to attach the file...it has following file in c:\musicplayer
Directory of C:\musicplayer
04/19/2014 02:12 PM <DIR> .
04/19/2014 02:12 PM <DIR> ..
04/19/2014 02:12 PM 0 filename.txt
04/19/2014 01:42 PM 0 Files.txt
10/01/2013 09:11 AM 1,288 MQn.bat
04/18/2014 11:15 PM 234,496 mqncontrol.exe
04/18/2014 11:15 PM 81,408 mqnplay.exe
10/01/2013 09:12 AM 4,150 MQnreadme.txt.txt
10/01/2013 09:13 AM 107 MQnStop.batbak
10/01/2013 09:14 AM 568 mqntest.bat
04/19/2014 01:43 PM <DIR> otherfile
04/19/2014 01:42 PM 47 param.txt
10/01/2013 09:13 AM 4,096 paste.exe
10/01/2013 09:14 AM 79,360 playerextreme.exe
10/01/2013 09:14 AM 16,896 WASAPI_test.exe
12 File(s) 422,416 bytes
3 Dir(s) 61,775,732,736 bytes free
when i click copy from musicplayer directory i get this in param txt file
C:\musicplayer\misty.wav
C:\musicplayer\lavezine.wav
V
you dont need files or param
your folder should look like this
https://www.dropbox.com/sh/z67howe0uno7i4x/Inl6e5XVzo
thisisvv
Post by thisisvv »
nige2000 wrote:you dont need files or param
tried that as well
04/19/2014 02:15 PM <DIR> .
04/19/2014 02:15 PM <DIR> ..
04/19/2014 02:15 PM 0 filename.txt
04/19/2014 02:14 PM 1,288 MQn.bat
04/19/2014 02:14 PM 245,760 mqncontrol.exe
04/19/2014 02:14 PM 82,432 mqnplay.exe
04/19/2014 02:14 PM 4,096 paste.exe
7 File(s) 429,832 bytes
3 Dir(s) 61,771,337,728 bytes free
still not work...
darkpink
Post by darkpink »
tried that as well
still not work...
Use mqnplay.exe 24 bit sse2 10ms R2.3 win7 and whatever mqncontrol you like with WIN7 and it will work with that OS, the other ones is for R2 and 8.1.
I just got mqncontrol.exe, mqnplay.exe, mqnload, (Data folder with ffmpeg.exe and flac.exe)
Windows7 was the bit I was wondering about the files and param don't affect it playing. All the latest versions are for 8 and 2012R2.
Maybe Gordon can point out suitable early versions to try with Windows7.
thisisvv
Post by thisisvv »
still unable to work...it flashes and then nothing happens
V
sbgk wrote:R2.73 another step up
Can't do nothing, but agree with you! ;-)
Specially the middle range is very impressive.
It reminds me when I heard for the first time the 448. For me so far the best one.
cvrle59
Post by cvrle59 »
Just got brand new pair of speakers...got to get up to speed with you guys.
cvrle59 wrote:Just got brand new pair of speakers...got to get up to speed with you guys.
Nice speakers seem to be universally liked. I know cloneys stock them but have never heard a pair. Congrats and best of luck with them.
Sounds nice to me as well. Great depth and detail.
