jesuscheung wrote: ↑Fri Dec 01, 2017 7:23 am
btw, after playing music for a while, the sound sometimes get distorted with noises with all new versions
sometimes its ok....
need fix this bug
i think your win10 build is 16299.19
do update windows, JC. my win10 build is 16299.64, SQ better, and have not this bug as yours.
need fix this bug
has learned code, not found bugs.
already update OS Build 16299.98 in MS page, improvements and fixes may things. i think we will update soon?
maybe bug can be fixed.
lekt wrote: ↑Mon Dec 04, 2017 5:19 am
optimized code and uploaded:
v3.76.1 movsb
v3.76.2
i suspected that in previous versions bypass function NtDeviceIoControlFile with parameters, so can raise bug as in your case.
try test bug, maybe has been fixed.
lekt wrote: ↑Fri Dec 08, 2017 7:15 am
v3.76.1 movsb
v3.76.2
3.75x seems ok now... Maybe coz I didnt restart computer after windows update or something.... ?!
3.76.2 is the best of lekt!
all things MUCH better
clarity much improved
amazing sound density
sound is rock solid!
can hear A LOT MORE details+depth at end of all notes, words!
bass is full here
timing better
v3.76.1 movsb is almost as good. emotion seems better. but sound is not as solid. density lesser.
