DJ le Roi
Post by DJ le Roi »
Hello SBGK, Thanks for your beautiful software. It's very good. Two questions. I have an AMD A6 3650 processor and I am using the 2.59 SSE2 version. Is this the best version for my processor? And, is there a difference in sound quality between SSE2 and SSE4 versions? In other words, can I get better sound quality with a SSE4 computer? Thanks!
Clive101
Post by Clive101 »
jesuscheung wrote:
Clive101 wrote: My CPU is an Intel Core i5 2500T which is quad core SSE4 and running Windows 8.1 64 bit. My DAC is a dCS Debussy connected via on board USB. It doesn't have any drivers as it uses the Mirosoft USB driver. I have had this working with JPLAY5.1 and JRIVER Kernel streaming and JRIVER via WSAPI all fine.
In Windows I can see the dCS as a sound device and it plays fine and have tested it via JRiver and it plays in all modes (ie Kernel streaming, WSAPI, WAV Out etc)
Really appreciate any help or advice on what to try / test to get MQN playing.
Regards
Clive
install:
1. download MQn.bat, paste.exe, a version of mqncontrol.exe, a version of mqnplay.exe.
2. put them all in one folder.
3. if you download mqncontrol.exe no affinity v2, make sure rename it as mqncontrol.exe.
4. if you down mqnplay.exe 2.60 sse4 intel, make sure rename it as mqnplay.exe
play a 16/44100 file, must be wav.
1. ctrl+c to copy the music file.
2. double click MQn.bat
3. music should come out.
https://drive.google.com/folderview?id= ... Utbm8#list
Hi
Have tried as above - no luck I'm afraid - no sound, have downloaded files and copied to c:\musicplayer folder. I have tried lots of different mqnplay versions and mqncontrol versions but nothing plays and I am selecting many different 16 44100 files. I can't believe I'm having such problems, and yet no one else seems to be??
Regards
Clive
theres this other player http://code.google.com/p/bitspersamplec ... ayPcmWinEn
that lets you select the output format
can you see which formats work for you
Regards
Clive
install:
Hi
Regards
Clive
can you run the wasapi_test program that's in the test folder, needs to be run from a cmd prompt, you list the devices and then list the formats for the selected device, post the results of event on exclusive on section. beware the brackets that look like <> are actually () (if your device name has brackets)
was it you who said the usb was 1.0, don't know if that would affect things as can't do asynch
DJ le Roi wrote:Hello SBGK, Thanks for your beautiful software. It's very good. Two questions. I have an AMD A6 3650 processor and I am using the 2.59 SSE2 version. Is this the best version for my processor? And, is there a difference in sound quality between SSE2 and SSE4 versions? In other words, can I get better sound quality with a SSE4 computer? Thanks!
looks like sse2 for your cpu, I would say there is a step up in SQ with sse4, I don't listen to sse2.
cvrle59
Post by cvrle59 »
Clive
Have you tried to unplug USB cable and play it on your computer audio only?
That would help in troubleshooting somehow, to make sure if problem is in your computer only, or computer and DAC don't "understand" each other.
have uploaded 2.59 sse4 intel 8 4 16 16 4 to compare with 8 4 16 16 8, haven't listened to it yet.
Having a bit of a listen and just don't want to change from the version of 2.59 I am using. How do I confirm the version? Is it just view properties of the control file?
TBH any version I have tried which generally are the recommended ones have been excellent.
As Father Ted would say 'They all have lovely bottoms'
tony wrote:Having a bit of a listen and just don't want to change from the version of 2.59 I am using. How do I confirm the version? Is it just view properties of the control file?
don't rename the file, copy and rename so you still have the original. look at which files you've downloaded, failing that rename it to a .bak file and post it to mqn-justgoodmusic@hotmail.co.uk and I'll tell you.
Clive101
Post by Clive101 »
sbgk wrote: can you run the wasapi_test program that's in the test folder, needs to be run from a cmd prompt, you list the devices and then list the formats for the selected device, post the results of event on exclusive on section. beware the brackets that look like <> are actually () (if your device name has brackets)
Hi sbgk
Thank you for your help - here's the output of the Event On Exclusive On section:
EXCLUSIVE: on EVENT DRIVEN: on
32000 24 2 192000 6 65534 22 24 3 - Format works ok
44100 24 2 264600 6 65534 22 24 3 - Format works ok
48000 24 2 288000 6 65534 22 24 3 - Format works ok
88200 24 2 529200 6 65534 22 24 3 - Format works ok
96000 24 2 576000 6 65534 22 24 3 - Format works ok
Regards
Clive
