lekt wrote:i was busy a long time, have less time for coding now. still difficult analys code of kse layer, many objects in protected mode, will do again with kse.
code of v3.55 256 ses is good, sound very nice. rewriten one function in audioses.dll layer and can remove one thing in render loop, i feel sound really better.
uploaded:
v3.55.2 256 , v3.55.3 256 nocrit , v3.55.4 256
try them and compare SQ, what is more correct..
i don't like 3.55.3 256 nocrit
3.55.2 and 3.55.4 are very very good, very much alike.
seems that 3.55.4 better. better bass quantity
3.55.4 seems kept all good things of ses. better softness. better clarity in treble. new best?
yes, v3.55.4 better, i also like its treble, mellow sound.
try v3.55.5 ses2 , think it works for onboard sound card. there's test version, new code, must be better then old ses code. still not optimized code. test vibration, i feel this vibration will good for piano sound, will use this code for optimization.
lekt wrote:yes, v3.55.4 better, i also like its treble, mellow sound.
ses2 seems to improve on slow notes. YET, fast notes is as good as before!
feels like this version is a breakthrough
ses2 is much more relax. doesn't try hard at all. beats all recent lekts with ease!
overall sound feels different. need more testing
NOTE, closing cmd will exit ses2 from playing.
made correction for some instructions that i've suspected vs goon-heaven PCI card. hope in this case i found bug, 2 these versions join into kse layer, but PCI card don't like trick with kse, hehe...
JC, try these versions, maybe SQ changed to good side?
r9 has sweeter mid but lesser bass.
seems r9 has more clarity than original versions.
overall, prefer original versions of 3.55.4 and 3.55.5 ses2- my favorites
especially prefer ses2, brings out the words of lyrics better
goon-heaven, pls. try test versions:
v3.57 256 test , v3.57 256 test2 uploaded into TEST_SOUNDCARD folder of my drive google. im waiting for feadback...
hihi... have diagnose that your PCI card calls different sub function, not the same as in onboard soundcard case. by logical, next versions base on kse and ses2 code will work for you, hope this. thx.
ses2 show that sound very free, JC, good vibrates. closing cmd will exit ses2 from playing: yes code doesn't run function FreeConsole.
