Clive
Post by Clive »
What does avx R2.20 need to run? I've tried 10ms R1.1, running mqnplay in compatibility mode for W8 and W7. No luck. The original avx version some weeks back worked.
New version of AVX R2.20 still not working for me on Haswell/Ciúnas even though I tried a couple of MQNcontrol's including 10ms R1.1. Giving the same error ""MQNplay has stopped working""
All suggestions welcome.
New prerequisite Gordon has to put the control file and new play in a folder clearing marked dorks pick this one it works and it is new.
Sorry in case anybody is offended that is just a special file for me
tony wrote:New prerequisite Gordon has to put the control file and new play in a folder clearing marked dorks pick this one it works and it is new.
Tony, does that makes you "special"?! :)))))
Ehh Yes! But I think you want to be special also?
I am special, just ask my teachers from my Special School, they doubted that I will ever learn to talk!
So, I want my "special" file! I'm fully qualified!
John Dot
Post by John Dot »
Is there any problem to release that file? Is it some .ini for MQn? I want it badly then.
uploaded sse4 R2.24, small tweaks to try and pick up the sound a bit with control R1.1. tremendous bass definition.
Ken Moreland wrote:New version of AVX R2.20 still not working for me on Haswell/Ciúnas even though I tried a couple of MQNcontrol's including 10ms R1.1. Giving the same error ""MQNplay has stopped working""
does sse4 work ? can't help as no avx works for me.
nige2000 wrote:
sbgk wrote:
nige2000 wrote:prefer mqncontrol 100000 over MQNcontrol.exe 10ms R1.1
I prefer 1.1 and technically it is a better solution, heard detail I've never heard before in classical music, just made it more musical.
yes detail is great
but a little flat too
yes, unexpected that. I'm sure noise is being reduced, R2.24 sounds a bit better, but again all I've done is to remove something that was producing noise.
