You know the bug with the little bit of music replaying after playback has ended? 2 bits of info:
1. v5.1 is in development and will have a potential fix for this
2. At Marcins suggestion I set the packet size to 400. Hasn't happened since.
Anyone tried JPlay?
Re: Anyone tried JPlay?
1. That certainly has. Great so easy in the end. That could be a return to base upgrade from other manufacturers and €200 to cover the 'miracle improvements'Fran wrote:You know the bug with the little bit of music replaying after playback has ended? 2 bits of info:
Now that is sorted I think you should chop this thread up a bit Fran. The usb stick carry on should be on a separate thread!
You're right Tony - lets move to discuss the usb key thingy under the building an audio PC thread?
I'm a bit too lazy to move the relevant posts there - and anyway they're mixed up anyway.....
Carry on....
Carry on....
I carried on and unfortunately if you wait long enough between tracks the glitch is still there.Roll on version 5.1
You set packetsize to 400 and are still getting the glitch?
mmm. Even Josef has said that while they are trying t address this in 5.1, it might not sort everyone out. I wonder because my audio PC is not exactly great - and ancient yoke tbh...... packet size making a difference would suggest that its something to do with networking.
You are using wifi? I can try connected the streamer by cable. Once you are at the pc and ready with the next choice the replay is avoided but if you sit and wait for me anyway it is still there. It is not worry but certainly would not sound great at a demo trying to flog the software.Fran wrote:You set packetsize to 400 and are still getting the glitch?
The audioPC is connected via cable to the router, the controlPC is working via wifi to the same router. So a mix I suppose.
And I just realised I have been typing "packetsize" when I meant "xstramsize" being set to 400.
John/Ken/Pearse/Tony - and any other jplay 5 users - have you tried the different packetsize options? I've tricked about a bit with it and based on casual listening, I seem to have settled on 4 - which means that it sends bigger chunks of data at 6sec intervals rather than a continuous stream. Any observations?
describe the bug to me i hadn't noticed anything. once the track ends it ends for me, only thing i noticed was the last track ending before its over. packet size set at 1 or 2
Xtreamsize=1500
Xtreamsize=1500
- Ken Moreland
Hi Fran, I,m using PacketSize=1 or 0 , minimum buffer size. I rarely have a repeat end playback.My Xtreamsize=1500.
- Ken Moreland
New JPlay V5.1 beta released on request from support@jplay.eu .Reputed to cure the repeat ending bug but also has a new ULTRAstream engine and better sound from all the other engines.
