Aleg wrote:
Could you also make container size a configurable parameter?
thought about it and think it's best to keep them separate.
sbgk wrote:R2.16 might be worth a listen to
I don't know if is my "Main page" handicapped also, or is just myself, but i don't see the R2.16!
Only R2.15!
Only R2.15!
Gordon already moved it to Archive (I don't know why), but can be found here:
It is worth a listen.
Didn't think 2.16 was better than 100000 or 2.3
Can we have 2.3 detail back?
Only R2.15!
Thanks Aleg,
I started to look into Archive, but soon I started to get dizzy and gave up! ;-)
don't see R.2.16...
R2.15 > R2.3
R2.3 has strain. false air. ears can get tired.
R2.15. richer sound. air kept. flow seems different. vocal decay/depth seems lacking a little bit. memory reminds me 100000 was perfect at vocal decay. unable to a b compare. 100000 is on strike.
uploaded sse4 R2.17, one of the most detailed versions I've heard.
plus 2.18 which is 2.17 dialled back a bit
and 2.19 just a bit more, that's more like it.
and with R2.20 hopefully we see the beginning of the end. Just try 2.20, no need for the others.
R2.22 just about perfect, to my lugholes anyway. Alfred Brendel on the old joanna never sounded so good.
Clive
Post by Clive »
I've just tried R2.22 (and R2.15). they won't play. The files load then MQN terminates. This is the first time I've tried any R2. I had been on R1.4. All W8.1
I'm using R1.1 512 mmcss control; am I using the the wrong mqncontrol.exe?
Edit: A pal sent his mqncontol.....it works. I must have got them mixed up.
R2.22 is very good , just listening to it now, very impressed.
taggart
Post by taggart »
R2.22 gives only crackling sound here.
