Like
Yes
22
100%
No
0
No votes
Total votes: 22
what about leaving the top exposed and running a strap down the center of the top piece ?
relieves the need for a lid
It is possible to bolt the top frame down without the lid Nige but for safety the lid might help any nasty accidents of dropping some thing conductive on top of the batteries with all those terminals exposed.
Will have a look at adding tabs on the ends for a strap across the middle for those more adventurous than me :-)
The lid will have the least of material and should not take long to print, hope to have the lid and rods printed tomorrow.
Looks fab, really!
Sligolad wrote: Thu Mar 02, 2017 8:01 pm It is possible to bolt the top frame down without the lid Nige but for safety the lid might help any nasty accidents of dropping some thing conductive on top of the batteries with all those terminals exposed.
yes was starting to have an afterthought about the extra safety that lid brings
Savage
I threw together another design yesterday as another option to allow more space down the sides, need to load some batteries in the test prints first to see if we can give up the side anchors and get away with just the 2 anchors on the ends.
The prints are highest speed and still feel solid though you do not get the smooth finish you see in the rendered pictures.
I modeled a strap across the top as well but forgot to render it before leaving work yesterday.
Anyway a last option that if strong enough might be the final design with the option of a strap down the middle as well.
This Cover has slots for the looped wiring given it is a narrower design.
I will give you a call Nige to organise meeting up over today or tomorrow to get some batteries and give you a feel for the test prints.
Fascinating stuff lads. Tale a collective bow
Pearse called down earlier with the first examples of cradles
id guess it would me no harm to have the cells a little looser, its a smidge too tight
you can see in the pic a small bulge in the middle cell
i kinda like the lid now, and would be super cool if we could write, it did not explode... YET project and all our names after it?
theres a support ridge in the lid that would prevent wire links crossing it
anyway im super stoked the way things is shaping up
oh and we need to avoid putting bolts though the bottom vent, you can probably guess with the pic where they need to go
nige2000 wrote: Sat Mar 04, 2017 10:19 pm Image
I will add another 0.1mm to the width Nige and that should do it for fit, will test it next week on the batteries I took away with me.
Will experiment to see if I can add text to the Lid.
I will add a cut out to the rib in the middle of the Lid.
Regarding not putting bolts through the vents are you thinking of installing the Cases parallel to the 2 vent arrays like in the first Pic above or perpendicular like in the second Pic above?
I will build the next sample with the end fixing points in case you prefer to keep them parallel to the Vents.
this is sorta the layout
thanks for coming down with the cradles
