it does sound faster and less noisejkeny wrote:Very good - it could be a result of using silver wiring or a larger gauge (lower impedance) for power carrying wiring?nige2000 wrote:ran silver wire from both +/- 3.3v at switch to shift registers, i had intended 16 runs to gnd too but i got lazy so maybe thats for another day
definitely another improvement, transients are faster, more separation and clarity
looks a bit chaotic
wonder if theres a tidier way to do it
dont know how silver does what silver does, but i love the stuff for resolution and clarityI've no theoretical reason why but I've heard the difference silver wire can bring.
but unforgiving on the noisy and jittery
i dont usually use it for experiments coz of the cost
but i soldered to the pads and this fine silver wire is nice stuff
its doesnt mind been bent a few times and far less likely to rip a pad off this is why i used it
yea there's definitely something special,I think the quality of this tweaked DAC is now revealing these small improvements which otherwise remain hidden by noise & other distortions in "normal" DACs
was listening to eva cassidy earlier the best of album
this album sounds a right bit different than it did a few mods ago, its not really so apparent in all tracks more so in acoustic and live stuff it kinda changes the way words are pronounced or strings are played but in a more accurate/natural way like the crack of a whip sounds natural, dacs arent usually fast/dynamic/resolution /low noise/low jitter enough to get the woosh /snap /echo /decay in a way thats well...... believable
its all the wires i dont like, the close soldering its a bit of a nestIt might be interesting to hear if 16 separate ground wires to the shift regs makes a difference & then if twisted wiring is any different
