lekt player
Re: lekt player
lekt wrote:---------for people who is intersting try lekt player:
from v3.43 256 win10 lekt player developed for windows 10 (don't work in win8/8.1/ws2102/ws2012r2).
the last time tried analysis and rewrite code from standard functions of wasapi core. now render loop can bypass 2 layers (audioses.dll and audiokse.dll), but code becomes much, big file size, and code very complex, optimized but i think still not best optimization. will do more in next versions.
v3.44 kse need improve balance, i see not good alignment in code.
JC, if you will update windows with kernel dll file set then notice me. audioses.dll and audiokse.dll may change algorithm in future. windows everyday makes optimization.
goon-heaven: we are waiting for your, maybe your hardware system have issue with win10?
win10 is last Microsoft operating system with trademark "Windows", think we don't need change OS in future, hehe...
lekt, 3.43 256 not work with my desktop PCI soundcard, help!
Re: lekt player
lekt wrote: JC, if you will update windows with kernel dll file set then notice me. audioses.dll and audiokse.dll may change algorithm in future. windows everyday makes optimization.
windows will upgrade itself... no stopping it from win10 home
lekt wrote: goon-heaven: we are waiting for your, maybe your hardware system have issue with win10?
(although i started not care about my desktop sound anymore hehe...
as all software get better, my realtek onboard sound quality is catching up with my STX card hehe)
lekt
Re: lekt player
Post by lekt »
yes, remember version xx for win8.1 when bypass second layer then goon-heaven sound card can't work with it.
your case as the same as goon-heaven. for PCI card seems need bypass only first layer of wasapi..
uploaded v3.44.1 256 norel
think works for onboard card. code lesser, file size small. try test it.
Re: lekt player
lekt wrote:yes, remember version xx for win8.1 when bypass second layer then goon-heaven sound card can't work with it.
seems all things better. quantity improved here -> less hard more fine-grained vibration
bass vocal emotion little less strong
mid is here, more correct
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:lekt, 3.43 256 not work with my desktop PCI soundcard, help!
v3.43 256 win10 uses all standard functions, no trick, no bypass anything. will review code.
v3.44x works for your PCI card?
my audioses.dll version is 10.0.10240.16412, audiokse.dll is 10.0.10240.16384, combase.dll is 10.0.10240.16384.
v3.44x makes one little trick for function CoInitializeEx from combase.dll, but i accurately defined pointer of needed system code area.
Re: lekt player
ok
mid vocal emotion is more correct
overall better
Re: lekt player
sorry, 3.43 works!
3.44 kse opens cmd and the cmd disappears, no sound
3.44.1 norel opens cmd, no sound
lekt
Re: lekt player
Post by lekt »
OK, will made version which bypass only first layer, maybe useful for PCI card.
still not good code alignment, i feel balance have little issue and negative affect to bass.
v3.39 256 lea very good made code alignment, render loop by 32 bytes alignment block boundary, many other code areas also in this status. sometimes good code alignment brings better SQ than good algorithm, hehe..
need do all things good once. will compile v3.39 256 lea for win10, i love its sound, good strong vocal.
goon-heaven
Re: lekt player
Post by goon-heaven »
Good evening my friends...
OK, win10 enterprise eval is up.
3.43 plays excellent... trounces SQ from my previous server2012 setup.
3.44 kse stops immediately
3.44.1 norel runs but no audio reaching soundcard
(So similar experience as JC)
No updates here - unplugged from the ether.
Keep up the good work!
Re: lekt player
nice goon!
win10 is insane... spent a month, all tweaks failed.... only tweak working is unintall apps, but must keep those apps MS want you to have... and finally disk clean later ...
after all, lekt is right from the start, windows need no tweak haha
(only bios tweaks work now)
