uploaded 24 bit 512 sse2 intrinsic R1.0 versions for win 7 and 8.1/r2, use with control 512. Think it sets a new standard for MQn, at least.
internethandle
Post by internethandle »
Thanks Gordon, answered my question perfectly! mqnplay.exe 24 bit 512 sse2 intrinsic R1.0 win7 + mqncontrol.exe 24 bit R1.0 512 win8.1-r2 not only works on my Win 7 build, but sounds mighty fine.
internethandle
Nevermind - doesn't seem to work with my DAC, unfortunately, although it (like some other MQn versions) I can get working with my Realtek onboard sound...
So back to mqnplay.exe 2.71 intel v2 it is, the best sounding and latest version that works with my DAC and OS. The decay just sounds the most correct, and the sound the most balanced/analog.
100000>1.5 448 @ 448/various clockrates
most of magic is gone
but still something in 448
maybe get other frequencies working on 100000 and move to ks
internethandle wrote:Nevermind - doesn't seem to work with my DAC, unfortunately, although it (like some other MQn versions) I can get working with my Realtek onboard sound...
did you try R2.0
taggart
Post by taggart »
mqnplay.exe 24 bit 512 sse2 intrinsic R1.2 win 8.1-r2 pgo => crackling sound.
mqnplay.exe 24 bit 512 sse2 intrinsic R2.0 win 8.1-r2 => works!
uploaded 1.3 sse2 24 bit.
+ 2.1 sse2 24 bit
John Dot
Post by John Dot »
sbgk wrote:uploaded 1.3 sse2 24 bit.
+ 2.1 sse2 24 bit
I think this might be the best version so far.
+ 2.1 sse2 24 bit
All versions are measured against the 100000 and none make it IMHO.
Why not continue from 100000 instead of trying to find other approaches that sound as good as 10000?
Or at least release a 24-bit and a 32-bit version of 100000, so there is a complete set from the 100000.
Clive101
Post by Clive101 »
Hi
I'm struggling to play anything but 24bit 96 KHz Wav files on my dCS Debussy Dac that wants everything in 24 bit containers.
I have an i5 CPU - which version of MQNplay and MQNcontrol should I download to play 16bit wavs on my DAC?
I'm running Windows 8.1 64 bit.
I am a bit confused by all the versions / combinations so really would appreciate some advice if anyone has an idea.
Many thanks
Clive
