nige2000 wrote:...
any chance of removing the clockrate child lock on the mqnplay.exe too
Nigel
I just make a file called clockrate448.reg which contains:
Code: Select all
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile\Tasks\Pro Audio]
"Clock Rate"=dword:000001c0
and run it immediately after the appearence of the mqncontrol window.
cheers
aleg
m5lig wrote:mqncontrol.exe 24 bit R1.1 512 win8.1-r2 mmcss clock rate
mqnplay.exe 24 bit R1.1 512 win8.1-r2
Plays without a hitch
More 3 dimensional sound
Bass is enhanced compared to R1.0 , this much improves the overall listening pleasure in my system . This combo is my new reference.
Crackling occurs on R1.5 448 , and I haven't yet found a solution.
I thought R1.1 had a strange effect on the sound, have you tried 2.5 or 3.5 ?
suppose the best thing would be to parameterise everything and then you could really go to town testing for the best settings.
Aleg wrote:
nige2000 wrote:...
Nigel
Code: Select all
cheers
aleg
no sound with throwing this in straight after hitting the mqn.bat
no matter what i change the clockrate in the reg file to
unable to test properly
did get a glimmer of hope out of it though
nige2000 wrote:
Aleg wrote:
nige2000 wrote:...
Nigel
Code: Select all
cheers
aleg
Hmmm, I have been using this all evening yesterday to switch to and fro different clockrates and compare the effects.
What version are you testing this with and does that version give sound without this registry update?
If you have no sound to begin with, I doubt this change of setting will give you sound.
I'll check again tonight, I'm now doing this from memory from the office.
1.5 448 control and play
will try again
nige2000 wrote:1.5 448 control and play
will try again
Do you see the value change in the registry editor when running this .reg file?
will try again
reg file works perfect
only get sound using it if i let the sound come before i execute the reg file
the crackling at the beginning of tracks is more annoying atm
but both will need to be fixed
without the crackling and at the forced clockrate on 16 44 the 448 is better than 512
even at this clockrate a glimmer of magic shines through
dont mind testing various clockrates but i do still need to benchmark
cvrle59
Post by cvrle59 »
I am confused what you are trying to accomplish here? Control programs change clock-rate automatically, plus you can do it manually in regedit.
cvrle59 wrote:I am confused what you are trying to accomplish here? Control programs change clock-rate automatically, plus you can do it manually in regedit.
It changes automatically to 11610, but they prefer 448.
You will have to change manually every time you start MQn.
