Jared wrote:....have you heard this incredibly uplifting disk?
No Jared but it is on the Wish List!
well, move it up a notch or two... ;-)
String Quartets Op. 18, 1-3....
Ciaran
Post by Ciaran »
+ 1. Most excellent.
Biber's Missa Bruxellensis with Jordí Savall
and Missa Christi Resurgentis with Andrew Parrott
are similar works in very good pereformances: Jared, if you like the first you should try these!
Now 1 becomes 3!!!!
thank you, Ciaran, I have seen the first of those around, however never the 2nd... both will be born in mind, most certainly! There really is nothing more uplifting than some Biber!
fergus wrote:String Quartets Op. 18, 1-3....
I see you're starting off gently, Fergus...
you know you've reached op.133 & 135 when your brain starts to simmer, before reaching the boil.. ;-))
incidentally, I'll shortly be joining you in the same traversal... I own the above set, and have recently purchased the Budapest's re-release on Sony..
Jared wrote: incidentally, I'll shortly be joining you in the same traversal... I own the above set, and have recently purchased the Budapest's re-release on Sony..
Good, we can compare notes as I am just starting off on something of an oddyssey myself with the Beethoven String Quartets!
Beethoven – Missa Soemnis....
This was a really wonderful performance from beginning to end!
Well done Jared, you won't be disappointed. Fergus, have you got a copy of the set?
