sounds goodnige2000 wrote:im playing with it only with 16 44jesuscheung wrote:can't help you if you don't know what buffer size your DAC likes...nige2000 wrote:JC what clock rate you using with 100000
Do you think clock size and period size connected?
just don't forget 44100's clockrate is wrong for hires playback.
think most people here uses 23220. doesn't work for hires
remember to change it
with 100000 i like 448 clockrate
dunno if thats related to my dac or the period size of this version
from my experience, correct rate gives max resolution
for my setup:
352 > 320 > 448~256
best clockrate can make sound worse, as it is just reflecting jitters of OS.
448 in my setup can very easy sound good with other software players too.
makes sense, 448 has lower res, more compromising.
448/44100=10159. (tightest clockrate)
try loosen it to 10160, it is even more compromising. it is even less resolution. but it is more easy to sound good.
same for timer resolution. 0.5ms doesn't compromise at all. it will reflect bad sound if OS/software is bad or hardware is slow(e.g. downclocking CPU).
software player itself doesn't decide all the sound.
why same WASAPI sounds different in 8.1 and R2?
because one must have metro. one can get rid of it.
every little thing affects sound.
