If the bbb had an external mclk working on slave mode would it solve the issue?
Bbb unsuitable clocks?
Funny it wouldn't give me permission sudo or not
I'll try later
Tweaker's Rash
Re: Tweaker's Rash
Re: Tweaker's Rash
You could always run
% cd /
% rm -r *
and go listen to a CD...
(NB This is a joke!)
% cd /
% rm -r *
Nerdcave: ...is no more!
Re: Tweaker's Rash
But quite tempting sometimes!Diapason wrote:You could always run
% cd /
% rm -r *
The proposed TPA cape will provide high spec clocks for both 44.1k and 48k file families (there is no common multiplier for both samplerate groups).nige2000 wrote:If the bbb had an external mclk working on slave mode would it solve the issue?
The BBB clock is apparently low spec - which is understandable given the retail price. But it will accept clock input so should be solvable. The "Botic" driver from Miero is designed to work with the cape Russ White is designing. It'll feed clocks into the BBB (and off to a DAC if required), bring the I2S interface out to suitable headers and offer access to the I2C bus to enable control of the Buffalo control registers for volume, filter setting and such.
Mark
Re: Tweaker's Rash
Aplay -l
No such command?
Or something similar
Jeezz
Getting to be a pita
No such command?
Jeezz
Re: Tweaker's Rash
I understand how you feel!nige2000 wrote:Aplay -l
No such command?
Jeezz
I get the same feeling soon as I start my regular PC.......of course, IF it starts! :))))
Re: Tweaker's Rash
Nige, are you running Linux Beaglebone 3.8.13-bone41? Or Volumio?nige2000 wrote:Aplay -l
No such command?
Jeezz
Volumio does not seem to display alsa information.
Mark
Re: Tweaker's Rash
3.8.13
Had volumio running ok though but usb nor nas would work with it
