Went back again to listening to 100000, V7 and V14.
100000 very open and wide soundstage
V14 somewhat closed in and restrained
V7 again more space than V14
100000 and V7 very close, hard to differentiate, believe 100000 a bit more free and longer sounding reverb, and allows to flow a little bit better than V7.
Overall I would prefer 100000 over the others
Difficult times again.
uploaded v15, think that's about the best I can get it. Shall upload the other versions over the weekend.
only tried an odd one between v7 and v15
dont think v7 is bettered yet it has the best dynamic range
100000 has the best detail, its what im using to listen to music when im not testing stuff
sbgk wrote:uploaded v15, think that's about the best I can get it. Shall upload the other versions over the weekend.
V15 has gone the wrong way AFAIC, it has lost details and spatial character.
In my setup it sounds a bit clogged up, not with the airyness and openess of V7 or 100000.
It would not be my favourite.
v15 128 might have more detail
v7 had a mistake so was not the correct way of doing things.
100000 is too lightweight for me.
sbgk wrote:...
Not at all, wonderfully deep and sonorous bass notes with a tremendous amount of microdetails and vibrations.
You should try to find this CD:
Alexander Ivashkin - Tatyana Lazareva - Prokofiev - Complete works for cello & piano (Chandos', CHAN 10045, England, 2003.)
and play the final track:
Sonata for cello solo in C sharp minor, Op. 134 (completed by Vladimir Blok)
This is my favourite test track for display of microdetails and depth of bass. It is wonderfully rich in wood and string vibrations of the cello and has incredible depth of bass. And besides it is a very beautifull piece of music.
Aleg wrote:
sbgk wrote:...
difficult to get the balance right, can you try v16, it sounds more like a 100000 version.
am getting some sweet sounds from v16, hopefully that is the code settled. Just need to determine the best period sizes.
Thanks to Nigel am trying out V7. Think I need to go back to school! Anyway sounds Bleedin brillant.
V16 and some of the others don't seem to be on the download drive?
tony wrote:Thanks to Nigel am trying out V7. Think I need to go back to school! Anyway sounds Bleedin brillant.
v16's been there since 21:00.
just uploaded a 512 16/44 version of v16 play/control ie period is close to 100000 and is 512 samples, 2048 bytes - I don't enjoy that sound though.
