lekt player
Re: lekt player
uploaded "next song.bat". it plays next song.
https://drive.google.com/?authuser=0#fo ... DQ2bnhPSDQ
if you didn't know it already, you can use win8 built-in thing to assign hotkey.
1. create shortcut of "next song.bat"
2. right click "properties"
3. look for "Shortcut key"
4. put the shortcut on desktop or somewhere that will activate the hotkey.
5. cheers!
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:uploaded "next song.bat". it plays next song.
5. cheers!
thx, JC. im using your tools, very good support for lekt.exe.
File MOD: modify the file PE section: can do with lekt.exe? tried, but crashed after change, not run. in 64bit file see heap & stack size position not like as instruction. did'nt try with driver.
Re: lekt player
5. cheers!
download "Stud_PE" to edit. much easier.
64bit heap & stack size is different to 32bit's. pkshan added the 64bit tweak yesterday.
original:
modified:
if cannot see images, http://blog.sina.com.cn/s/blog_72b3301c01019877.html
Re: lekt player
finally finished modding my soundcard driver. pretty sure it is correct now. let's hope so... hehe...
yesterday i didn't do it right. it was good effects + bad effects
today, it seems totally good!
shall try modding lekt and mqn now
Re: lekt player
still have not done it right... damn... cannot just mod every dll and sys file. this mod requires listening skill and technical skill.
Re: lekt player
alright. modded 2.23. definitely works! must try it.
think that i like 2.23 better than 2.25x. (did many mods. cannot do detail commenting)
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:alright. modded 2.23. definitely works! must try it.
ha ha.. attack to the heap and stack! now lekt.exe is lekt/XA/JC, very interesting, how much better 2.23 ? 10-20%. im waiting for you, send it me, OK. so then next v2.26 will be +20%, maybe we with you will be the top of the world! hehe..
Re: lekt player
Re: lekt player
lekt wrote:maybe we with you will be the top of the world! hehe..
need pkshan. he's the king of tweaks.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:uploaded 2.25 v2 mod. try try!
ok, better some %, you're also master of tweaks, interesting. pls. check private message.
